Now with pictures!
Subject
- Posted on
- surrealarmada
March 7, 2007, 9:37 am
Good evening,
My LAN management guys are reporting that " interface is down with our
Cisco switch " . I have checked the log files on the Cisco switch and
I found the following errors:
23w5d: %LINEPROTO-5-UPDOWN: Line protocol on Interface
FastEthernet0/6, changed state to up
FastEthernet0/6, changed state to down
23w5d: %LINK-3-UPDOWN: Interface FastEthernet0/6, changed state to
down
23w5d: %LINK-3-UPDOWN: Interface FastEthernet0/6, changed state to up
down
The interface is down for few seconds and comes up again multiple
times.
Any ideas? Cheers, Rob
surrealarmada@gmail.com
Re: changed state to up changed state to down FastEthernet LINEPROTO-5-UPDOWN
Bad or loose cable? Invalid settings (duplex mismatch or something the like)?
Regards,
Christoph Gartmann
Max-Planck-Institut fuer Phone : +49-761-5108-464 Fax: -452
Immunbiologie
Postfach 1169 Internet: gartmann@immunbio dot mpg dot de
D-79011 Freiburg, Germany
http://www.immunbio.mpg.de/home/menue.html
I have some nodes which do this when they reboot. First, etherenet comes up
"default", then the powerup script defines the ethernet port and the port
temporarily goes down, then as the OS (VMS in my case) comes up, at one point,
it takes over the ethernet port and it also goes down for a second or two.
no logging event addr-flap
carrier-delay 10
Will help. It basically tells the switch to wait 10 seconds before declaring
that the ethernet link is down. The first one reduces the number of syslog
messages being issued.
Sorry about that . addr-flap doesn't seem to work. And I can't find a reference
for it either (although my switch says it supports it.
SWITCH1(config-if)#logging event ?
addr-flap Enable and Disable Address Flap messages
link-status UPDOWN and CHANGE messages
subif-link-status Sub-interface UPDOWN and CHANGE messages
Obviously, link-status is the one to really remove it. It seems to generate 2
messages (LINEPROTO-5 and LINK-3 messages) whenever the link changes.
Site Timeline
- » Test SFP on Catalyst 3560
- — Next thread in » Cisco Systems
- » I have strange routing problem with my C3560 switch.
- — Previous thread in » Cisco Systems
- » Cisco CP 2.7
- — Newest thread in » Cisco Systems
- » Verizon Direct Marketing [telecom]
- — The site's Newest Thread. Posted in » General Telecommunications Forum
- » Tell Verizon to bring back FTP [telecom]
- — The site's Last Updated Thread. Posted in » General Telecommunications Forum
