Here is my configuration:
I bought a 3620 router to help me study for my ccna. I have a cable modem. It is connected to a d-link broadband wireless router I have set up basic rip on the 3620. Networks 192.168.0.0 and 192.168.1.0 are specified after router rip All networks are /24
I have asigned 192.168.0.2 on interface e0/0 - this goes to the cable router. It's internal IP is 192.168.0.1 - the cable modem has dhcp set up - I have a Windows 2003 server, DNS/WINS on this subnet. 192.168.0.101 - The server is A/D, hosting the Test.local domain - There is a switch between the server, 3620, and the cable router I have asigned 192.168.1.1 on interface e0/10 - this goes to workstation, 192.168.1.2 - the workstation is a member of the Test.local domain - it can not login with the router in place.
- there is a switch between the workstation and the 3620
Here is my problem:
1) From the second pc, I can not ping the cable router 2) From the server, I can not ping the workstation 3) From the Router I can ping the cable router 4) From the Router I can ping the workstationshow ip route: C 192.168.0.0/24 directly... C 192.168.1.0/24 directly ....
My conclusions: There is a DNS error somehow, but I have a DNS/WINS server running. Without the 3620, my workstation points to the DNS server successfully For it's WINS/DNS needs, and everything, including Internet searches, works. Is there a way to specify my dns/wins server for the cisco router?
=================================================== Building configuration...
Current configuration : 763 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname Router1 ! ! ! ip subnet-zero ! ! ! ! ! ! ! ! ! ! ! ! ! interface Ethernet0/0 ip address 192.168.0.2 255.255.255.0 half-duplex ! ! interface Ethernet0/1 ip address 192.168.1.1 255.255.255.0 half-duplex ! ! router rip network 192.168.0.0 network 192.168.1.0 ! no ip http server ip classless ! ! ! ! ! gatekeeper shutdown ! ! line con 0 line aux 0 line vty 0 4 ! ! end
