CCNA - ICND question help
I need help on a question from the CCNA-ICND test.
I didn't pass for a second time, and got the exact same score of
837/1000. 849 is a pass.
I believe this problem is what I've been getting wrong:
2 things needed:
- correct addressing on RtrA
- correct LAN config on RtrB
Server & Host Y need to be able to communicate.
Connections: Host consoled to RtrA
RtrA s0/0 connected to RtrB s0/0 RtrA fa0/0 connected to Sw1
Sw1 connected to Server 10.1.1.148/24
RtrB fa0/0 connected to Sw2
Sw2 connected to Host Y 192.168.3.28/24
Config's:
RtrA: s0/0
192.168.2.5/30
fa0/0
10.1.1.147/24
rip 10.0.0.0 rip 192.168.2.0
RtrB:
192.168.2.6/30
fa0/0
192.168.3.27/24 shut
rip 192.168.2.0 rip 192.168.3.0
Of course I enable RtrB fa0/0, which is half of the answer. I can't figure out any problems with the addressing on RtrA.
Can someone help me? I'd really appreciate it. Thanks
kade714
I failed it with 845.....
Just a thought, but if ip subnet-zero isn't enabled on each Router (A and B), would RouterA's address of 192.168.2.5/30 be the network- address for that subnet?
Arthur Brain
Hi Arthur, I believe the subnet address is 192.168.2.4/30. The 2 hosts would be .
5 & .6. The broadcast would be .7.
kade714
OK, sorry, I punched all this into my home lab and the addressing is fine. All my studying without it and I forgot I even had it.
So, what could they be asking for when they say to fix/correct the addressing on RtrA then? Anyone have any ideas?
Anyone recently pass the ICND? Thanks again
kade714
Addressing seems to be ok... Was this a simulation question? Did you try to ping from Host Y to the server? simulation might be considered incomplete if you did not ping the server. Maybe you need to provide clocking to one of the routers...
sek
