CBQoS Mib object index vlaue confusion
I am working with Cbqos mib snmp and i have 2 policy's configured on the router, one for the policing and other for marking. below is the config
policy-map POLICE
class SIGNALING
police 10000000 conform-action transmit exceed-action drop
policy-map MARKING class ABC set ip precedence 6 set qos-group 6 class XYZ set ip precedence 5 set qos-group 5 class EFG set ip precedence 1 set qos-group 1 class MISC set ip precedence 0 set qos-group 0
Now Policy MARKING is applied on multiple interfaces of the router IN direction
when we see the cbqos Actions in tool, we see that interface is doing marking and Policing action also, but in config we see tht we have configured it for marking only.
After some troubleshooting, i saw tht cbqos object index which should be unique, its not below is the walk which clarifies it ...
same index value is been used for the multiple running instance of service-policy MARKING
ciscoMgmt.166.1.5.1.1.2.16.1 : Unsigned32: 17223898
ciscoMgmt.166.1.5.1.1.2.16.65536 : Unsigned32: 351686093
ciscoMgmt.166.1.5.1.1.2.16.65537 : Unsigned32: 621087690
ciscoMgmt.166.1.5.1.1.2.16.65538 : Unsigned32: 1939966601
ciscoMgmt.166.1.5.1.1.2.16.131072 : Unsigned32: 351551825
ciscoMgmt.166.1.5.1.1.2.16.131073 : Unsigned32: 651568212
ciscoMgmt.166.1.5.1.1.2.16.131074 : Unsigned32: 1893000480
ciscoMgmt.166.1.5.1.1.2.16.196608 : Unsigned32: 309953102
ciscoMgmt.166.1.5.1.1.2.16.196609 : Unsigned32: 622917584
ciscoMgmt.166.1.5.1.1.2.16.196610 : Unsigned32: 1895345379
ciscoMgmt.166.1.5.1.1.2.16.262144 : Unsigned32: 378168697
ciscoMgmt.166.1.5.1.1.2.16.262145 : Unsigned32: 572510174
ciscoMgmt.166.1.5.1.1.2.16.262146 : Unsigned32: 1895460567
ciscoMgmt.166.1.5.1.1.2.16.327680 :Unsigned32: 1593
ciscoMgmt.166.1.5.1.1.2.16.327681 :Unsigned32: 1594
ciscoMgmt.166.1.5.1.1.2.32.1 : Unsigned32: 17223898
ciscoMgmt.166.1.5.1.1.2.32.65536 :Unsigned32: 351686093
ciscoMgmt.166.1.5.1.1.2.32.65537 :Unsigned32: 621087690
ciscoMgmt.166.1.5.1.1.2.32.65538 :Unsigned32: 1939966601
ciscoMgmt.166.1.5.1.1.2.32.131072 : Unsigned32:351551825
ciscoMgmt.166.1.5.1.1.2.32.131073 :Unsigned32: 651568212
ciscoMgmt.166.1.5.1.1.2.32.131074 :Unsigned32: 1893000480
ciscoMgmt.166.1.5.1.1.2.32.196608 :Unsigned32: 309953102
ciscoMgmt.166.1.5.1.1.2.32.196609 :Unsigned32: 622917584
ciscoMgmt.166.1.5.1.1.2.32.196610 :Unsigned32: 1895345379
ciscoMgmt.166.1.5.1.1.2.32.262144 :Unsigned32: 378168697
ciscoMgmt.166.1.5.1.1.2.32.262145 :Unsigned32: 572510174
ciscoMgmt.166.1.5.1.1.2.32.262146 :Unsigned32: 1895460567
ciscoMgmt.166.1.5.1.1.2.32.327680 :Unsigned32: 1593
ciscoMgmt.166.1.5.1.1.2.32.327681 :Unsigned32: 1594
Is this a Normal behaviour where the service instance runing on the multiple interface will have the same object index value ?
As per the Doc the Config Index value should be unique per Policy Map config. But below walks show that same Index Value has been used for the 2 differnet Policy map.
cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2432.1 : INTEGER: policymap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2432.65536 : INTEGER: classmap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2432.65537 : INTEGER: matchStatement cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2432.65538 : INTEGER: set cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2432.131072 : INTEGER: classmap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2432.131073 : INTEGER: matchStatement cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.1 : INTEGER: policymap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.65536 : INTEGER: classmap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.65537 : INTEGER: matchStatement cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.65538 : INTEGER: police cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.131072 : INTEGER: classmap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.131073 : INTEGER: matchStatement cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.131074 : INTEGER: police cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.196608 : INTEGER: classmap cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.196609 : INTEGER: matchStatement cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.196610 : INTEGER: police cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.262144 : INTEGER: classmap
cbQosObjectsTable.cbQosObjectsEntry.cbQosObjectsType.2482.262145 : INTEGER: matchStatement
