Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by kartikvashishta108 on June 19, 2009, 1:36 am
boot> sh mo
Mod Ports Module-Type Model Serial-Num Status
--- ----- --------------------- -------- --------- ------- 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty What may be the fault, how do I troubleshoot? boot> sh te
LCP Diag Status for Module 1 (. = Pass, F = Fail, N = N/A) CPU : . Sprom : . Bootcsum : . Archsum : N RAM : . LTL : . CBL : . DPRAM : . SAMBA : . Saints : . Pkt Bufs : . Repeater : N FLASH : N SAINT/SAGE Status : Ports 1 2 3 -------------- . . . Packet Buffer Status : Ports 1 2 3 -------------- . . . boot>
boot> sh mo
--- ----- --------------------- -------- --------- ------- 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty 2 12 10/100BaseTX Ethernet WS-X5213A 006592679 other 3 12 10/100BaseTX Ethernet WS-X5213A 005863060 other 4 12 100BaseFX MM Ethernet WS-X5111 002916333 other Mod MAC-Address(es) Hw Fw Fw1 --- ---------------------------------------- ------ -------- -------- 1 00-10-2f-19-38-00 thru 00-10-2f-19-3b-ff 2.1 2.4(1) 2.4(1) 2 00-e0-1e-7d-68-c8 thru 00-e0-1e-7d-68-d3 2.0 1.4 3 00-e0-b0-a2-e9-54 thru 00-e0-b0-a2-e9-5f 2.0 1.4 4 00-60-3e-8e-12-40 thru 00-60-3e-8e-12-4b 1.0 1.3 Mod Sub-Type --- -------- 1 unknown boot>
boot> sh fl
File Version Size (bytes)
-------------- ----------------- ------------- c5000 nmp 0.0(5) 1999605 boot>
boot> sh sy
Modem Baud
------- ----- disable 9600 boot>
Kartik Vashishta | ||||||||||||||||||||||||||||||||||||||||
Posted by kartikvashishta108 on June 19, 2009, 1:51 am
Please log in for more thread options > On a catalyst 5000, I see:
=A0 =A0Archsum =A0: N
> > boot> sh mo > Mod Ports Module-Type =A0 =A0 =A0 =A0 =A0 Model =A0 Serial-Num Status > --- ----- --------------------- -------- --------- ------- > 1 =A0 2 =A0 =A0 100BaseTX Supervisor =A0WS-X5509 006776932 faulty > > What may be the fault, how do I troubleshoot? > > boot> sh te > > LCP Diag Status for Module 1 =A0(. =3D Pass, F =3D Fail, N =3D N/A) > =A0CPU =A0 =A0 =A0 =A0 : . =A0 =A0Sprom =A0 =A0: . =A0 =A0Bootcsum : . = > =A0RAM =A0 =A0 =A0 =A0 : . =A0 =A0LTL =A0 =A0 =A0: . =A0 =A0CBL =A0 =A0 =
=A0: . =A0 =A0DPRAM =A0 =A0: .
> SAMBA : .
LASH =A0 =A0: N
> =A0Saints =A0 =A0 =A0: . =A0 =A0Pkt Bufs : . =A0 =A0Repeater : N =A0 =A0F= >
w =A0 =A0 Fw =A0 =A0 =A0 Fw1
> =A0SAINT/SAGE Status : > =A0 Ports 1 =A02 =A03 > =A0 -------------- > =A0 =A0 =A0 =A0 . =A0. =A0. > > =A0Packet Buffer Status : > =A0 Ports 1 =A02 =A03 > =A0 -------------- > =A0 =A0 =A0 =A0 . =A0. =A0. > boot> > > boot> sh mo > Mod Ports Module-Type =A0 =A0 =A0 =A0 =A0 Model =A0 Serial-Num Status > --- ----- --------------------- -------- --------- ------- > 1 =A0 2 =A0 =A0 100BaseTX Supervisor =A0WS-X5509 006776932 faulty > 2 =A0 12 =A0 =A010/100BaseTX Ethernet WS-X5213A 006592679 other > 3 =A0 12 =A0 =A010/100BaseTX Ethernet WS-X5213A 005863060 other > 4 =A0 12 =A0 =A0100BaseFX MM Ethernet WS-X5111 002916333 other > > Mod MAC-Address(es) =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 =A0 H= > --- ---------------------------------------- =A0------ -------- --------
.4(1)
> 1 =A0 00-10-2f-19-38-00 thru 00-10-2f-19-3b-ff =A02.1 =A0 =A02.4(1) =A0 2= > 2 =A0 00-e0-1e-7d-68-c8 thru 00-e0-1e-7d-68-d3 =A02.0 =A0 =A01.4
> 3 =A0 00-e0-b0-a2-e9-54 thru 00-e0-b0-a2-e9-5f =A02.0 =A0 =A01.4 > 4 =A0 00-60-3e-8e-12-40 thru 00-60-3e-8e-12-4b =A01.0 =A0 =A01.3 > > Mod Sub-Type > --- -------- > 1 =A0 unknown > boot> > > boot> sh fl > File =A0 =A0 =A0 =A0 =A0 =A0Version =A0 =A0 =A0 =A0 =A0 =A0Size (bytes) > -------------- =A0----------------- =A0------------- > c5000 nmp =A0 =A0 =A0 0.0(5) =A0 =A0 =A0 =A0 =A0 =A0 1999605 > boot> > > boot> sh sy > Modem =A0 Baud > ------- ----- > disable =A09600 > > boot> > > Kartik Vashishta I could enable/disable ports..... set port enable/set port disable how to make this permanent(the enable and disable of ports)? Success in enabling and disabling ports led me to believe that the catalyst 5000 is working fine...it has two power supplies, only one has been plugged in... Kartik Vashishta | ||||||||||||||||||||||||||||||||||||||||
Posted by Brian V on June 19, 2009, 8:15 am
> > boot> sh mo > Mod Ports Module-Type Model Serial-Num Status > --- ----- --------------------- -------- --------- ------- > 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty > > What may be the fault, how do I troubleshoot? > > boot> sh te > > LCP Diag Status for Module 1 (. = Pass, F = Fail, N = N/A) > CPU : . Sprom : . Bootcsum : . Archsum : N > RAM : . LTL : . CBL : . DPRAM : . > SAMBA : . > Saints : . Pkt Bufs : . Repeater : N FLASH : N > > SAINT/SAGE Status : > Ports 1 2 3 > -------------- > . . . > > Packet Buffer Status : > Ports 1 2 3 > -------------- > . . . > boot> > > boot> sh mo > Mod Ports Module-Type Model Serial-Num Status > --- ----- --------------------- -------- --------- ------- > 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty > 2 12 10/100BaseTX Ethernet WS-X5213A 006592679 other > 3 12 10/100BaseTX Ethernet WS-X5213A 005863060 other > 4 12 100BaseFX MM Ethernet WS-X5111 002916333 other > > Mod MAC-Address(es) Hw Fw Fw1 > --- ---------------------------------------- ------ -------- -------- > 1 00-10-2f-19-38-00 thru 00-10-2f-19-3b-ff 2.1 2.4(1) 2.4(1) > 2 00-e0-1e-7d-68-c8 thru 00-e0-1e-7d-68-d3 2.0 1.4 > 3 00-e0-b0-a2-e9-54 thru 00-e0-b0-a2-e9-5f 2.0 1.4 > 4 00-60-3e-8e-12-40 thru 00-60-3e-8e-12-4b 1.0 1.3 > > Mod Sub-Type > --- -------- > 1 unknown > boot> > > boot> sh fl > File Version Size (bytes) > -------------- ----------------- ------------- > c5000 nmp 0.0(5) 1999605 > boot> > > boot> sh sy > Modem Baud > ------- ----- > disable 9600 > > boot> > > Kartik Vashishta >I could enable/disable ports.....
>set port enable/set port disable >how to make this permanent(the enable and disable of ports)?
>catalyst 5000 is working fine...it has two power supplies, only one >has been plugged in... >Kartik Vashishta
Your in boot mode, means you have no valid software image. Can't do anything until you get that fixed! | ||||||||||||||||||||||||||||||||||||||||
Posted by Thrill5 on June 19, 2009, 11:36 pm
Please log in for more thread options "faulty" probably means that the supervisor failed one its boot up
diagnostic tests. It looks to me that the system has booted and the "boot>"
prompt is probably just the default. This switch is 10 to 15 years old so
you can probably get a replacement supervisor on ebay for pretty cheap. What are you using this thing for? Hopefully you didn't buy this for Cisco experience because this thing isn't anything like an IOS based switch. >
>> >> boot> sh mo >> Mod Ports Module-Type Model Serial-Num Status >> --- ----- --------------------- -------- --------- ------- >> 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty >> >> What may be the fault, how do I troubleshoot? >> >> boot> sh te >> >> LCP Diag Status for Module 1 (. = Pass, F = Fail, N = N/A) >> CPU : . Sprom : . Bootcsum : . Archsum : N >> RAM : . LTL : . CBL : . DPRAM : . >> SAMBA : . >> Saints : . Pkt Bufs : . Repeater : N FLASH : N >> >> SAINT/SAGE Status : >> Ports 1 2 3 >> -------------- >> . . . >> >> Packet Buffer Status : >> Ports 1 2 3 >> -------------- >> . . . >> boot> >> >> boot> sh mo >> Mod Ports Module-Type Model Serial-Num Status >> --- ----- --------------------- -------- --------- ------- >> 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty >> 2 12 10/100BaseTX Ethernet WS-X5213A 006592679 other >> 3 12 10/100BaseTX Ethernet WS-X5213A 005863060 other >> 4 12 100BaseFX MM Ethernet WS-X5111 002916333 other >> >> Mod MAC-Address(es) Hw Fw Fw1 >> --- ---------------------------------------- ------ -------- -------- >> 1 00-10-2f-19-38-00 thru 00-10-2f-19-3b-ff 2.1 2.4(1) 2.4(1) >> 2 00-e0-1e-7d-68-c8 thru 00-e0-1e-7d-68-d3 2.0 1.4 >> 3 00-e0-b0-a2-e9-54 thru 00-e0-b0-a2-e9-5f 2.0 1.4 >> 4 00-60-3e-8e-12-40 thru 00-60-3e-8e-12-4b 1.0 1.3 >> >> Mod Sub-Type >> --- -------- >> 1 unknown >> boot> >> >> boot> sh fl >> File Version Size (bytes) >> -------------- ----------------- ------------- >> c5000 nmp 0.0(5) 1999605 >> boot> >> >> boot> sh sy >> Modem Baud >> ------- ----- >> disable 9600 >> >> boot> >> >> Kartik Vashishta >
>>catalyst 5000 is working fine...it has two power supplies, only one >>has been plugged in... >
>>Kartik Vashishta
> Your in boot mode, means you have no valid software image. Can't do > anything until you get that fixed! | ||||||||||||||||||||||||||||||||||||||||
Posted by bod43 on June 20, 2009, 12:12 am
Please log in for more thread options > "faulty" probably means that the supervisor failed one its boot up
so
> diagnostic tests. =A0It looks to me that the system has booted and the "b= oot>" > prompt is probably just the default. =A0This switch is 10 to 15 years old= > you can probably get a replacement supervisor on ebay for pretty cheap.
isco
> What are you using this thing for? =A0Hopefully you didn't buy this for C= > experience because this thing isn't anything like an IOS based switch.
> >> boot> sh mo
> >> Mod Ports Module-Type Model Serial-Num Status > >> --- ----- --------------------- -------- --------- ------- > >> 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty >
> >> boot> sh te
> >> LCP Diag Status for Module 1 (. =3D Pass, F =3D Fail, N =3D N/A)
> >> CPU : . Sprom : . Bootcsum : . Archsum : N > >> RAM : . LTL : . CBL : . DPRAM : . > >> SAMBA : . > >> Saints : . Pkt Bufs : . Repeater : N FLASH : N >
> >> SAINT/SAGE Status :
> >> Ports 1 2 3 > >> -------------- > >> . . . >
> >> Ports 1 2 3 > >> -------------- > >> . . . > >> boot> >
> >> boot> sh mo
> >> Mod Ports Module-Type Model Serial-Num Status > >> --- ----- --------------------- -------- --------- ------- > >> 1 2 100BaseTX Supervisor WS-X5509 006776932 faulty > >> 2 12 10/100BaseTX Ethernet WS-X5213A 006592679 other > >> 3 12 10/100BaseTX Ethernet WS-X5213A 005863060 other > >> 4 12 100BaseFX MM Ethernet WS-X5111 002916333 other >
> >> --- ---------------------------------------- ------ -------- -------- > >> 1 00-10-2f-19-38-00 thru 00-10-2f-19-3b-ff 2.1 2.4(1) 2.4(1) > >> 2 00-e0-1e-7d-68-c8 thru 00-e0-1e-7d-68-d3 2.0 1.4 > >> 3 00-e0-b0-a2-e9-54 thru 00-e0-b0-a2-e9-5f 2.0 1.4 > >> 4 00-60-3e-8e-12-40 thru 00-60-3e-8e-12-4b 1.0 1.3 >
> >> Mod Sub-Type
> >> --- -------- > >> 1 unknown > >> boot> >
> >> boot> sh fl
> >> File Version Size (bytes) > >> -------------- ----------------- ------------- > >> c5000 nmp 0.0(5) 1999605 > >> boot> >
> >> boot> sh sy
> >> Modem Baud > >> ------- ----- > >> disable 9600 >
> >> boot>
> >> Kartik Vashishta
> >>catalyst 5000 is working fine...it has two power supplies, only one > >>has been plugged in... >
> >>Kartik Vashishta
> > anything until you get that fixed! Just by way of some explanation. Many of the high end routers and switches had a three stage boot process. 1. rommon 2. IOS boot image 3. IOS main image I know that your 5000 is CAT-OS, I was at one time familiar with them, but it looks like you have done stages 1, and 2 but have got stuck at stage 3. I forget the commands now for CAT-OS but you should do something like "show boot" and "show flash" and post the results. sh boot sh bootflash sh slot0 sh flash slot0 sh slot1 sh flash slot1 I forget now. sh ver sh diag sh hard would be good too. | ||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| catalyst 5000 question | June 19, 2009, 1:36 am |
| Cisco Catalyst 5000 with Sup I | July 19, 2005, 5:44 am |
| catalyst 5000 max mtu / vlan | October 12, 2005, 3:29 am |
| Cisco catalyst 5000 pin layout | July 19, 2005, 7:09 pm |
| Questions: Cisco Catalyst 5000 | June 13, 2005, 9:10 am |
| Catalyst 5000 w/ Sup. III - Switching Fabric | June 22, 2005, 11:08 am |
| Catalyst 5000 Console cable | June 23, 2005, 9:56 am |
| VLANs between CISCO Catalyst 5000 and 3com Superstack 3 Switch 4900 | February 1, 2006, 3:24 pm |
| 2 ISP's one Cat 5000 switch! | August 7, 2005, 5:56 am |
| Cisco Nexus 5000 interfaces | December 9, 2009, 5:02 am |
| networking-forum.com reaches 5000 posts! | July 31, 2006, 10:49 am |
| QoS question, 3560 catalyst | October 19, 2005, 2:45 pm |
| Vlan question on Catalyst 2900 XL | April 10, 2006, 3:42 pm |
| ACL processing question for my Catalyst 6513 | February 23, 2009, 10:26 am |
| Catalyst 3750 StackWise failover question | May 9, 2006, 8:22 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
