Catalyst 3200/LS1010 Vlan trunking problem
Hi, i've got catalyst 3200 with some VLANs i need to trunk using the WS-X3006 ATM module and a Cisco LS1010. The LS1010 is doing LECS,LES and BUS, the cat3200 only LEC. From what i have read (i'm not an ATM/LANE expert) i need to configure an ELAN for every VLAN i need to trunk on the switch, with the same name, and the cat3200 should automatically join as a LEC every elan corresponding to its vlans with ports assigned. On the cat3200 the following VLANs are configured: "default", with no ports assigned, "labnet" with 10 ports, "privatenet" with the remaining ports, and the ATM configuration is done through ILMI... alas on the ELAN table on the 3200 i get only this: STATE/ ELAN NAME LES ADDRESS/BUS ADDRESS/LEC ADDRESS LECID TIME 1 default 00.000000000000000000000000.000000000000.00 0 Down 00.000000000000000000000000.000000000000.00 0:00:00 47.00918100000000603E5A4501.0080240B8B10.00
This is the LS1010 configuration ! version 11.3 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption service compress-config ! hostname LS1010 ! enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxxx ! username router password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx no ip routing ip domain-name hkzlab.net ip name-server 192.168.2.20 ! atm lecs-address-default 47.0091.8100.0000.0060.3e5a.4501.0010.0739.b105.00 1 atm address 47.0091.8100.0000.0060.3e5a.4501.0060.3e5a.4501.00 atm router pnni no aesa embedded-number left-justified node 1 level 56 lowest redistribute atm-static ! ! lane database LANE_DATABASE name default server-atm-address 47.00918100000000603E5A4501.00100739B103.00 name default elan-id 1 name privatenet server-atm-address 47.00918100000000603E5A4501.00100739B103.02 name privatenet elan-id 11 name labnet server-atm-address 47.00918100000000603E5A4501.00100739B103.01 name labnet elan-id 10 default-name default clock timezone GMT+1 1 clock summer-time ORA_LEGALE recurring last Sun Mar 2:00 last Sun Oct 2:00 ! ! interface ATM0/0/0 description connection to cat3200 no ip address no ip route-cache no ip mroute-cache no atm ilmi-keepalive ! interface ATM0/0/1 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM0/0/2 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM0/0/3 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM0/1/0 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM0/1/1 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM0/1/2 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM0/1/3 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM1/0/0 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM1/1/0 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM2/0/0 no ip address no ip route-cache no ip mroute-cache atm maxvp-number 0 lane config auto-config-atm-address lane config database LANE_DATABASE ! ! interface ATM2/0/0.1 multipoint no ip route-cache no ip mroute-cache lane server-bus ethernet default elan-id 1 ! interface ATM2/0/0.2 multipoint no ip route-cache no ip mroute-cache lane server-bus ethernet labnet elan-id 10 ! interface ATM2/0/0.3 multipoint no ip route-cache no ip mroute-cache lane server-bus ethernet privatenet elan-id 11 ! interface Ethernet2/0/0 ip address 192.168.1.230 255.255.255.0 no ip route-cache no ip mroute-cache ! interface ATM3/0/0 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! interface ATM3/1/0 no ip address no ip route-cache no ip mroute-cache shutdown no atm ilmi-keepalive ! ip default-gateway 192.168.1.1 ip classless ! banner motd ^C LS1010 HKZlab ATM switch ^C ! ! line con 0 login local line aux 0 line vty 0 4 password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx login local ! ntp clock-period 17180483 ntp server 192.168.1.160 end
This is a "show lane server" output: LS1010#show lane server LE Server ATM2/0/0.1, Elan name: default, Admin: up, State: operational Master/Backup: Backup, Type: ethernet, Max Frame Size: 1516 locally set elan-id: 1 elan-id obtained from LECS: not set ATM address: 47.00918100000000603E5A4501.00100739B103.01 LECS used: 47.00918100000000603E5A4501.00100739B105.00 connected, vcd 226
LE Server ATM2/0/0.2, Elan name: labnet, Admin: up, State: operational Master/Backup: Backup, Type: ethernet, Max Frame Size: 1516 locally set elan-id: 10 elan-id obtained from LECS: not set ATM address: 47.00918100000000603E5A4501.00100739B103.02 LECS used: 47.00918100000000603E5A4501.00100739B105.00 connected, vcd 285
LE Server ATM2/0/0.3, Elan name: privatenet, Admin: up, State: operational Master/Backup: Backup, Type: ethernet, Max Frame Size: 1516 locally set elan-id: 11 elan-id obtained from LECS: not set ATM address: 47.00918100000000603E5A4501.00100739B103.03 LECS used: 47.00918100000000603E5A4501.00100739B105.00 connected, vcd 195
If i run a "debug lane config all" i get these messages.
11:54:56 : LECS EVENT ATM2/0/0: placed register address 0x60F5C6E8 (47.00918100000000603E5A4501.00100739B105.00) request with ILMI 11:54:56 : LECS EVENT ATM2/0/0: 47.00918100000000603E5A4501.00100739B105.00: ilmi registered 11:55:00 : LECS EVENT ATM2/0/0: ATM_SETUP received: callid 0x6103C1BC 11:55:00 : LECS EVENT ATM2/0/0: calling party addr 47.00918100000000603E5A4501.0080240B8B10.00 (type=16 len=20) 11:55:00 : LECS EVENT ATM2/0/0: calling party is probably an LEC 11:55:00 : LECS EVENT ATM2/0/0: call ACCEPTED and sent a CONNECT to 0x6103C1BC 11:55:00 : LECS EVENT ATM2/0/0: ATM_CONNECT_ACK received: callid 0x6103C1BC 11:55:00 : LECS PACKET ATM2/0/0: packet received and enqueued 11:55:00 : LECS PACKET ATM2/0/0: a packet is received from a LEC 11:55:00 : --- LECS PACKET ATM2/0/0: dump of input packet --- opcode: 0x1 transaction_id: 2284 src_lan_dest: 0080.240b.8b10 11:55:00 : lan_type: 1 max_frame_size: 1 num_tlvs: 0 src_atm_addr: 47.00918100000000603E5A4501.0080240B8B10.00 name_size: 7 elan_name: default 11:55:00 : ------------------------------------------ 11:55:00 : LECS PACKET ATM2/0/0: found elan 'default' by name 11:55:00 : LECS PACKET ATM2/0/0: config request for elan 'default' succeeded 11:55:00 : LECS PACKET ATM2/0/0: added the elan-id (1) tlv to config response; num_tlvs = 1 11:55:00 : LECS PACKET ATM2/0/0: packet transmitted 11:55:00 : LECS PACKET: time units used: 4, total requests: 2478, total time units: 1244 11:55:00 : LECS EVENT ATM2/0/0: ATM_RELEASE received: callid 0x6103C1BC cause 31 11:55:00 : LECS EVENT ATM2/0/0: sending RELEASE_COMPLETE for call 0x6103C1BC cause 31 11:55:00 : LECS EVENT ATM2/0/0: final removal of connection obj for callid 0x6103C1BC 11:55:00 : LECS EVENT ATM2/0/0: call 0x6103C1BC cleaned up
I think the problem is in my LS1010 config, anyone got an idea? Thanks, Hkz
P.S. sorry for my english: i'm not a native speaker.
Hkz
Problem solved: i forgot to add the vlan to the atm trunk port on the catalyst 3200. Here's an ls1010 working config: Current configuration: ! ! Last configuration change at 01:29:00 GMT+1 Tue Dec 25 2007 by router ! NVRAM config last updated at 01:31:38 GMT+1 Tue Dec 25 2007 by router ! version 12.0 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption service compress-config ! hostname LS1010 ! enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXXXXXXX enable password 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx ! username router password 7 04480A0D01345F5D0C14 ip subnet-zero no ip routing ip domain-name hkzlab.net ip name-server 192.168.2.20 ! atm qos default cbr max-cell-loss-ratio clp0 255 atm qos default cbr max-cell-loss-ratio clp1plus0 255 atm qos default vbr-rt max-cell-loss-ratio clp0 255 atm qos default vbr-rt max-cell-loss-ratio clp1plus0 255 atm qos default vbr-nrt max-cell-loss-ratio clp0 255 atm qos default vbr-nrt max-cell-loss-ratio clp1plus0 255 atm lecs-address-default 47.0091.8100.0000.0060.3e5a.4501.0010.0739.b105.00 1 atm address 47.0091.8100.0000.0060.3e5a.4501.0060.3e5a.4501.00 atm router pnni no aesa embedded-number left-justified node 1 level 56 lowest redistribute atm-static ! ! lane database LANE_DATABASE name default server-atm-address 47.00918100000000603E5A4501.00100739B103.01 name labvlan server-atm-address 47.00918100000000603E5A4501.00100739B103.02 name privlan server-atm-address 47.00918100000000603E5A4501.00100739B103.03 default-name default clock timezone GMT+1 1 clock summer-time ORA_LEGALE recurring last Sun Mar 2:00 last Sun Oct 2:00 ! ! interface ATM0/0/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status no atm ilmi-keepalive ! interface ATM0/0/1 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM0/0/2 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM0/0/3 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM0/1/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM0/1/1 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM0/1/2 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM0/1/3 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM1/0/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM1/1/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM2/0/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status atm maxvp-number 0 lane config auto-config-atm-address lane config database LANE_DATABASE ! interface ATM2/0/0.1 multipoint no ip directed-broadcast no ip route-cache no ip mroute-cache lane server-bus ethernet default ! interface ATM2/0/0.2 multipoint no ip directed-broadcast no ip route-cache no ip mroute-cache lane server-bus ethernet labvlan ! interface ATM2/0/0.3 multipoint no ip directed-broadcast no ip route-cache no ip mroute-cache lane server-bus ethernet privlan ! interface Ethernet2/0/0 ip address 192.168.1.230 255.255.255.0 no ip directed-broadcast no ip route-cache no ip mroute-cache ! interface ATM3/0/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! interface ATM3/1/0 no ip address no ip directed-broadcast no ip route-cache no ip mroute-cache logging event subif-link-status shutdown no atm ilmi-keepalive ! ip default-gateway 192.168.1.1 ip classless ! line con 0 login local transport input none line aux 0 line vty 0 4 password 7 0017120D0A4E18150A2C login local ! ntp clock-period 17180182 ntp server 192.168.1.160 end
Oh, and Merry Christmas to everyone! Hkz
Hkz
