Hi all,
I am running a 2811, I have just installed a new HWIC but it is not to be 'detected'. I have tried to run the 'card type' but the command is not recognize.
The IOS version I am running is 12.4(15)T7.
Any one can help.
Thanks. Fell.
Hi all,
Any one can help.
Thanks. Fell.
Almost always the new HWIC needs newer version of IOS.
What does a 'show diag' give you about that slot you put it in?
Hi Doug,
You are right. The IOS version I am running is a bit old. I have to update it to the 12.4-20 at least. Versions above don't suppose this command.
Thanks for your answer.
Reg. Fell
fellugh a écrit :
Hi there,
I have just install the new IOS version : 12.4-20T The card command is 'here' but returns me :
------ r006748(config)#card type e1 1 Card in slot 1 was removed or does not support command. r006748(config)#
sh diag : WIC Slot 1: 1 port channelized and PRI T1/E1 HWIC
Do you have any idea ?
Fel.
I assume you have the HWIC-1CE1T1-PRI interface card.
The docs say you need to specify two numbers after the line type..
Otherwise, since 12.4(20T) is the very first version with support for HWIC-1CE1T1-PRI, maybe they messed up something, try something slightly newer?
Hi Doug,
Thanks for the link ... Yesterday, after the new IOS installed, I was a bit disappointed as I got an other error ... I posted my question to quickly because I found the solution by my own :
r006748#card type e1 0 1
But the link is really interesting.
Thanks anyway for your reply. Fell.
