Cisco Systems cant ping when adding secondary ip to 1 fastethernet interface on 1700 router
Subject Author Date
cant ping when adding secondary ip to 1 fastethernet interface on 1700 router jcharth 08-17-05
Posted by on August 17, 2005, 12:14 pm
I am testing on a local router adding a second ip. when i add a
secondary ip in the same subnet everything works but when i add a
secondary ip in a different subnet i cant ping from or to the router. i
also try adding a second ip route 0.0.0.0 0.0.0.0 mynewgateway but that
did not work. I will change providers soon and i would like to make
sure that when they put the router in the new location everything will
continue working. can this be done?
thanks
Posted by shen@axentra.net on August 17, 2005, 8:35 pm
(config-if)#no ip split-horizon
Posted by on August 18, 2005, 3:06 pm
Thanks, I almost thought that was going to work. I was adviced to set
the default route as the interface and worked better but it did not
solve the problem. I will upload the configuration to the router with
the changes using tftp that is probably the best way.
Similar ThreadsPosted
cant ping when adding secondary ip to 1 fastethernet interface on 1700 router August 17, 2005, 12:14 pm
adding a second ip to a cisco 1700 interface August 12, 2005, 8:22 am
Adding Secondary Power Supply to VPN 3015 December 1, 2005, 10:02 pm
Setting up a router with 29 Global IPs, BUT can't ping router internal interface from server or server interface from router December 11, 2005, 10:37 am
adding 8 port switch to ethernet interface on 1812 router May 29, 2006, 1:14 am
Adding secondary gateway to cisco 3550 switch for link fail over December 15, 2005, 12:09 am
allow PING from outside to router vlan interface October 23, 2008, 2:20 pm
AP : How to disable DHCP service on the Fastethernet Interface ? October 14, 2008, 12:59 pm
IRB BVI0 interface, no ping possible from the router to inside hosts September 17, 2008, 1:53 pm
Secondary IP address on PIX ethernet interface April 25, 2006, 12:55 pm
FastEthernet card not working in 12008 router November 2, 2005, 12:36 pm
Failover from primary router to secondary router with HSRP October 14, 2005, 3:56 pm
Adding an extra IP net to an external interface June 26, 2007, 8:16 am
Router on a stick w/o secondary IP July 4, 2005, 8:59 am
A non-Cisco router, BDCOM 1700 Router Series June 28, 2008, 4:27 am
