Hi, I'm trying to enable bridging between a serial interface (ppp encapsulated) and an ethernet on a 2800 router. here's the main config:
bridge irb bridge 1 proto ieee
int se 0/0/0:0 encap ppp bridge-group 1
int e0 bridge-group 1 ip address 192.168.1.1 255.255.255.0
On the other side of the serial connection, there's another router with similar config. Problem is one host on the ethernet of one router cannot reach the other host on the other router.
Is bridging on PPP supported at all?
TIA.
