Hello all ,
I have a 1600 serie router which don't start properly. After few seconds I have a the following prompt :
NameOfTheRouter(boot)#
I can't type command in this mode ...
Do you have ideas ?
Thanks in advance Regards, Olivier.
Hello all ,
Do you have ideas ?
In article , Olivier Le Tertre wrote: :I have a 1600 serie router which don't start properly. After few seconds I :have a the following prompt :
:NameOfTheRouter(boot)#
:I can't type command in this mode ...
:Do you have ideas ?
- Wrong router port (AUX instead of console?)
- wrong cable / broken cable
- broken terminal software
- broken serial port on the accessing device
- Wrong router port (AUX instead of console?) No, I check it.
No, this cable works on another router
The terminal works on another router
How can I check that ?
Olivier
