Blocking Audio Streaming
I'm trying to block my users to stream radios, I have found this post
regex audio-mpeg "audio/.*"
policy-map type inspect http test_radio parameters protocol-violation action drop-connection log match response header content-type regex audio-mpeg drop-connection log match request header user-agent regex _default_windows-media-player- tunnel drop-connection log
policy-map global_policy class inspection_default inspect http test_radio
This works pretty well, unfortunately some sites (channel933.com) are streaming through the https port, nothing is encrypted but it uses port 443, so I have tried to modify my policy map to "policy-map type inspect httpS test_radio" but of course my ASA 5505 do not want to hear about inspecting httpS
I will greatly appreciate a solution
If by chance you also have a solution to block ShoutCast radio, that will be nice :)
Thank you
Personne
