BGP question
I'm running multihomed BGP, two ISP lines connected to two separate routers. Want to know is it possible to force one of the inside host routing to one dedicated line and if this line goes down, it can route via the other line based on the BGP route table learned on the router ? Pls advise. If using PBR + set ip next hop x.x.x.x (line A), if line A goes down, will it failover to line B ?
Please advise,
yellow
Object tracking attached to route-map. Try this.
Igor Mamuzic aka Pseto
