BGP default route advertisement
Threaded View
I have 6 sites on a Verizon MPLS network, 4 office 2 datacenter. Each site
CE router is running BGP with the PE and is in the same AS with AS_Override
 enabled by the provider. I want to advertise the default route from my dat
acenters to the rest of the WAN via the BGP default-information originate,
but want one datacenter to be the preferred path and the other as the backu
p. What is the best and simplest way to influence this routing on the datac
enter CEs in the way it advertises routes to the peer ?
Re: BGP default route advertisement
On Wednesday, September 3, 2014 3:22:21 PM UTC-5, tmcgov05 wrote:
e CE router is running BGP with the PE and is in the same AS with AS_Overri
de enabled by the provider. I want to advertise the default route from my d
atacenters to the rest of the WAN via the BGP default-information originate
, but want one datacenter to be the preferred path and the other as the bac
kup. What is the best and simplest way to influence this routing on the dat
acenter CEs in the way it advertises routes to the peer ?
Does this help?
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bgp/configuration/
12-4/irg-12-4-book/irg-cost-comm.html
Site Timeline
