Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by linguafr on May 6, 2008, 8:06 pm
Please log in for more thread options different sites as long as these blocks are only in ebgp? | ||||||||||||||||
Posted by Trendkill on May 7, 2008, 7:10 am
Please log in for more thread options Yes, you cannot have the same LAN block IPs unless you are NATing, else your routers will have a problem. They will have a IGP advertisement to the network locally, and then they will have a BGP route to it at another site, and no matter which way they prefer, traffic between sites with the same range will catastrophically fail. If you want to do some kind of failover, you need to NAT the sites private side to the public addresses, and ensure your redundant providers are advertising your range to the internet, with one obviously preferred over the other unless there is a failure. If you are talking technically, technically you can do what you are asking, and the different router ID will ensure that routes are exchanged, but at layer 3, this design will fail. | ||||||||||||||||
| Similar Threads | Posted |
| bgp anycast addressing | May 6, 2008, 6:38 pm |
| bgp anycast addressing | May 6, 2008, 8:06 pm |
| does anyone use anycast | April 5, 2007, 11:01 pm |
| IP addressing | August 30, 2005, 5:31 am |
| VPN addressing | February 20, 2006, 1:14 pm |
| MAC Addressing | November 17, 2005, 3:33 pm |
| MAC Addressing | November 25, 2005, 3:18 pm |
| IP Addressing | August 28, 2006, 4:34 pm |
| Need Help with IP Addressing | September 8, 2006, 12:01 am |
| Cisco ASA - IP Addressing | August 27, 2006, 2:29 pm |
| VPN IP Addressing Problem | September 28, 2006, 10:26 am |
| IP addressing on an Ethernet subinterface | February 11, 2005, 1:38 pm |
| Cisco PIX 501 private addressing | December 14, 2005, 9:19 pm |
| VLAN IP Addressing Question | November 14, 2006, 10:32 am |
| Generic IP Addressing Question | January 3, 2007, 1:55 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
