Backup Routing Problem
Hello NG
I'm an Newbee with Routing and i have an Question about using Backup- Route
Following Problem :
2 Locations, connected with an WiFi Link, both side Cisco 3750. Each location also connected via VPN to Location 3. VPN Routing work's perfectly. Now i have to setup the WiFi Connection between Router A and B. VPN will be used for Backup then.
Router A
172.27.45.1/24 IP Route 0.0.0.0/0 172.27.45.254 172.27.70.0/24 172.27.45.2
VPN Gateway 172.27.45.254 WiFi Gateway 172.27.45.2
Router B
172.27.70.1/24 IP Route 0.0.0.0/0 172.27.70.254 172.27.45.0/24 172.27.70.2
VPN Gateway 172.27.70.254 WiFi Gateway 172.27.70.2
Router A connect to Router B by using WiFi Link. In Case WiFi Link is not available Routing have to change to VPN Gateway.
I didn't have any idea how to solve it. Is anyone able to help me ? Thanks in advance Peter
peter.blumenau
Use a "floating" static. You simply put a metric on the other static route.
ip route 0.0.0.0 0.0.0.0 172.27.45.2 ip route 0.0.0.0 0.0.0.0 172.27.45.254 200
The first on will be used if the WiFi link is up, but if not the second "floating" route via the VPN will be used.
Thrill5
It could be so simple ;-)
Thanks a lot. I will try it out.
Greet> Use a "floating" static. =A0You simply put a metric on the other static r= oute.
peter.blumenau
