Hi Group,
I am a newbie to Cisco and I am attempting to setup a autonomous Cisco
1142n access point running Version 12.4(21a)JA1.I am attempting to use the 2.4 Ghz Radio with WPA2 security and a local radius server on the Aironet and connect from my MacBook running OSX 10.6.
The Aironet (10.10.10.254) is connected to a Cisco Router (10.10.10.1).
In the Event Log I am getting a Debugging Level entry for Station
0019.e302.35e2 Authentication failed. I attempt to connect as user "TheUser" and password "thepassword".I have attached the configuration that the I have entered on the Aironet. I have tried both from the CLI and UI to setup. The commands below are from the CLI setup.
I am at a loss to what I have done wrong. Is there anything obvious?
Thanks
Stuart
Cisco1142n#show run Building configuration...
Current configuration : 2736 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Cisco1142n ! enable secret 5 $1$VvXP$rSnB8gKtv1pxFVqMDcyX6/ ! aaa new-model ! aaa group server radius rad_eap server 10.10.10.254 auth-port 1645 acct-port 1646 ! aaa group server radius rad_mac aaa group server radius rad_acct aaa group server radius rad_admin aaa group server tacacs+ tac_admin aaa group server radius rad_pmip aaa group server radius dummy ! aaa authentication login eap_methods group rad_eap aaa authentication login mac_methods local aaa authorization exec default local aaa accounting network acct_methods start-stop group rad_acct ! aaa session-id common ! dot11 syslog ! dot11 ssid Cisco1142n authentication open eap eap_methods authentication network-eap eap_methods authentication key-management wpa ! username Cisco password 7 032752180500 ! bridge irb ! interface Dot11Radio0 no ip address no ip route-cache encryption mode ciphers aes-ccm ssid Cisco1142n antenna gain 0 station-role root no dot11 extension aironet bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding bridge-group 1 spanning-disabled ! interface GigabitEthernet0 no ip address no ip route-cache duplex auto speed auto no keepalive bridge-group 1 no bridge-group 1 source-learning bridge-group 1 spanning-disabled ! interface BVI1 ip address 10.10.10.254 255.255.255.0 no ip route-cache ! ip default-gateway 10.10.10.1 ip http server no ip http secure-server ip http help-path
I am also a little confused on DHCP. Can I have the Aironet allocate DHCP address or should the router do that?
