I understand this is opposite of asymmetric routing. This is the initial setup. After this i will have another ISP connected , which will only provide incomming traffic to me. And another link will take care of outgoing traffic.
I feel this point it will make more complex. So i wants to acieve the following first.
Can i have some :***advice about the configration in my router ***
Exactly this is wht i wants to achieve. Main intention is to pass on the dedicated bw customer thru one link ( ISP) and shared customer thru
the other link (ISP). So the incomming traffic and out going traffic should take the intended
route. No load balance is required. Or else shared customer will take route of dedicated Link.
But if one link is down, the other can be used as backup.
Both the ISP will be connected to 2 different iterface of a single Router.
Will appreciate if you can suggest brief config too.
Thanks ! Kind Regards, SD
