Hi all,
I would like to config a ASA connection method is
(LAN1) - ASA 1 router1 ~ ~ ~ router2 ASA 2 - (LAN2)
if i'd want to ping from (LAN1) to (Lan2) I use static route only
1st I set the following to each route outside 0.0.0.0 0.0.0.0 192.168.133.3(router port which connected) I can communicate each otherQuestion is: Is that any problem with config the route using 0.0.0.0 0.0.0.0 ? Will it has packet loop problem?
Thanks a lot!
