Hi all,
We have CISCO access router AS 3660 with 30 mica modem. I would like to use this modems for inbound and outbound calls.
It is not problem to use modems for outbound calls. I just connect to the router using telnet to the dedicated modem (telnet router-ip
6000+line). Then I can enter AT commands.But problem is with inbound calls. I can also connect to the dedicated modem using telnet. But when I try to make a call to this modem, I see on opposite side response 'BUSY'. Is it possible to configure this mica modems for inbound calls?
Now I use for inbound calls 'autocommand connect' (see the configuration example bellow). But it is not very usable for me. I would like to connect to dedicated modem and wait for 'RING'. Can anybody help me?
Jaro
line 161 exec-timeout 0 0 timeout login response 0 flush-at-activation modem InOut modem autoconfigure type mica rotary 1 autocommand connect 172.16.34.76 2701 transport preferred telnet transport input all transport output lat pad v120 lapb-ta mop telnet rlogin udptn ssh autoselect during-login autoselect ppp
