I have no idea how to add on an additional Cisco 3560 switch. Can it be linked on to another switch and what else will I need to do this?
- posted
15 years ago
The wise snipped-for-privacy@gmail.com enlightened me with:
It depends. But perhaps a little information from you might result in a better answer. Stuff like whether you use vlans, vtp or any other stuff that makes managed switches worth their while over unmanaged switches. If all you are doing is having a bunch of switches in 1 LAN to connect workstations to, then yes, just connecting it should be enough, but I'd buy something cheaper for that. In all other cases: make sure the switches are configured according to your wishes.
Mark
