I've managed to get reflective ACL working. However, it adds ACL rules at the end of the ACL. Lots of rules when the LAN side machine makes a lot of connections to the outside world.
It creates a lot of redundant entries at the bottom such as :
permit tcp host 190.10.0.111 eq 52140 host 64.235.219.134 eq 6881
even though the acl already contains a : permit tcp any any eq 6881
From a performance point of you, is it better to use the "established" mechanism for tcp and use reflective only for udp ? This would greatly reduce the number of dynamic entries in the ACL.
for instance:
ip access-list extended ACLinbound evaluate Reflect_outbound permit tcp any any established permit tcp any 10.0.0.0 0.0.255.255 eq www deny tcp any any eq 445
ip access-list extended ACLoutbound permit tcp any any permit udp any any reflect Reflect_outbound
For tcp, does the reflective mechanism provide any additional functionality that the "established" mechanism doesn't ?
