Cisco Systems Wireless Clients Cannot Connect to Each Other
Subject Author Date
Wireless Clients Cannot Connect to Each Other tom 05-07-06
Posted by tom on May 7, 2006, 11:51 pm
Using a 871W, the clients on the wireless segment cannot connect to
each other (same subnet). Here is the relevant part of the config:
interface Dot11Radio0
no ip address
encryption key 1 size 40bit 7 XXXXXXXXX transmit-key
encryption mode wep mandatory
ssid myssid
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0
station-role root
no dot11 extension aironet
l2-filter bridge-group-acl
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip address 192.168.0.3 255.255.255.0
ip nat inside
ip virtual-reassembly
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Any thoughts?
Thanks
Posted by BG on May 8, 2006, 10:28 am
I dont see it in your config, but it sounds like you may have Public Secure
Packet Forwarding enabled.
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/122-15.JA/1100/h_ap_network-if_802-11_c.htm
bridge-group x port-protected
barry
> no ip address
> ssid myssid
> authentication open
> 36.0 48.0 54.0
> station-role root
> no cdp enable
> bridge-group 1
> interface Vlan1
> no ip address
> bridge-group 1
> interface BVI1
> ip nat inside
> control-plane
> bridge 1 route ip
> Any thoughts?
> Thanks
Posted by Merv on May 8, 2006, 10:54 am
> Using a 871W, the clients on the wireless segment cannot connect to each other
(same subnet).
1. Can EACH of the wireless workstation in question ping the BVI IP
address 192.168.0.3 ???
2. What does arp -a ( command windows) show on a given wirless
workstation when you ping one of the other wireless workstations ?
Posted by tom on May 8, 2006, 11:10 am
Yes, each can get to their gateway of 192.168.0.03
Tried this - they do not have each other's MAC in their arp cache.
Just that of 192.168.0.3
Nope - that is not in the config
Further ideas?
Thanks
Posted by Merv on May 8, 2006, 1:24 pm
Do you have a firewall enabled on these clients ?
If so disable it
Similar ThreadsPosted
Wireless Clients Cannot Connect to Each Other May 7, 2006, 11:51 pm
VPN on PIX 506E, only two clients can connect February 11, 2005, 5:52 am
Connect together cisco vpn clients October 9, 2006, 3:29 am
EZVPN Server - clients connect but cannot pass traffic.. August 31, 2005, 7:39 pm
Unable to Connect Multiple VPN Clients via Linksys Router October 20, 2006, 8:57 am
Cisco VPN clients unable to connect to 3725 VPN server January 18, 2008, 1:44 pm
Cisco 1121G AP and Linksys wireless clients October 10, 2006, 8:39 pm
Some wireless clients cannot detect my unbroadcast Aironet AP July 3, 2008, 11:21 pm
Cisco 876W Wireless Clients no Internet connectivity December 18, 2005, 4:48 pm
Wireless clients can't get DHCP address from router behind Aironet 1100 January 20, 2007, 2:10 pm
Cisco wireless access points: snmp query for number of clients September 6, 2006, 1:53 pm
877W - cannot talk wireless device to wireless device October 30, 2005, 3:35 am
VPN clients can't access OWA February 9, 2006, 9:58 pm
2 vpn clients on Home LAN April 19, 2006, 4:32 pm
