Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by thrdeye40 on May 8, 2008, 9:45 pm
Can someone explain the difference between a T1 and an ISDN PRI? I'm a bit confused on the differences between them. Thanks. | ||||||||||
Posted by Peter on May 9, 2008, 3:10 am
Please log in for more thread options In simple terms, the difference will vary depending on what part of the world you are in and how the provider delivers the service, however at the base level, a TI connection is a single open pipe of E1 capacity, while a PRI INCLUDES structured channels on the PRI build. In many cases the net effect is very similar, its just that the PRI has many more configurable items available. Here in New Zealand a PRI is delivered as 1920Kbps of Data made up from 30 x 64Kb 'B' channels plus 1 x 128Kb 'D" Management channel, while our equivalent of the TI is the E1 which is a single open 2048Kbps pipe. I hope this helps.......................pk. -- Peter from Auckland. | ||||||||||
Posted by Merv on May 9, 2008, 4:31 am
for defintions of each see T1/DS1 http://en.wikipedia.org/wiki/Digital_Signal_1 ISDN PRI http://en.wikipedia.org/wiki/Integrated_Services_Digital_Network Basically the difference is that a T1 is a point-to-point WAN circuit whereas an ISDN PRI uses T1/E1 as it transport to an ISDN switch and it has a signalling channel ( to setup and tear down calls) and 23 data channels (56KBPS/64Kbps) so it is a switched "circuit" service | ||||||||||
Posted by Thrill5 on May 11, 2008, 12:38 am
Please log in for more thread options An ISDN PRI is a T1 that is running the ISDN protocol. Same concept as an
MPLS or frame-relay circuit. A T1 is a WAN point-to-point circuit and ISDN is a voice signaling protocol. MPLS and frame-relay are data protocols that can run on top of a T1 circuit. > Hello,
> > Can someone explain the difference between a T1 and an ISDN PRI? I'm > a bit confused on the differences between them. > > > Thanks. | ||||||||||
| Similar Threads | Posted |
| What is the difference between a T1and an ISDN PRI | May 8, 2008, 9:45 pm |
| No difference between ....T and .....T3? | February 22, 2006, 10:33 am |
| Difference between PIX and ASA | May 29, 2006, 5:07 am |
| Difference in setting up ATM 0 or ATM 0.1 | February 8, 2005, 8:32 pm |
| Difference between PIX 501 and 800 series | July 9, 2005, 7:26 pm |
| Difference between SDM and SDM Express | July 18, 2007, 9:07 am |
| Difference between WICs and VWICs | July 6, 2006, 3:51 pm |
| Difference between 4500 and 4900. | August 21, 2006, 1:08 pm |
| routed port and SVI difference | March 30, 2007, 4:51 am |
| Difference - SUP2 vs. SUP32 | April 20, 2007, 1:54 am |
| difference between 3750 and 3750E | July 11, 2007, 1:24 pm |
| ASA IOS versions? Difference in Trains? | August 7, 2007, 1:25 pm |
| What is the difference between these two Cisco WAN Cards | October 31, 2007, 11:33 pm |
| Difference between 4.1.7 and 4.7.2 - Cisco VPN 3005 | April 15, 2009, 11:34 pm |
| Difference Between Collision and Broadcast Domain. | September 21, 2005, 12:52 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
