Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by kartik on March 24, 2006, 6:59 pm
My Cisco router has 3 interfaces. Fe0/0 is the incoming interface with all the web traffic from the clients. Fe0/1 is connected to the internet backhaul and Fe0/2 connects to the cache engine farm. I enabled wccpv1 (since my cache supports only that) on the cisco router and configured the ip wccp redirect out command in the Fe0/1 interface which is the path to the internet. I see that the response(I_See_You) from the cisco to the Here_I_Am messages from the cache server uses the source interface of Fe0/2 (since that is the closest interface to the cache farm LAN, I suppose). !!! Doing an show ip wccp web-cache detail shows the WebCache ID as 0.0.0.0.... Interestingly redirection is occuring on the cisco router when I try to browse (as indicated by the counters in the same command) but it is not working... is this because the gre tunnel is using a source interface of 0.0.0.0 ??? ANy ideas on how I can get the router to use the correct webcache ip address?? thanks, -Kartik | ||||||||||
Posted by kartik on March 27, 2006, 7:04 pm
Please log in for more thread options bug. The router is seeing the cache (show ip wccp detail). However my PIX firewall in between the router and the cache seems to be dropping the spoofed SYN ACK packet sent by the cache to the client. On digging further I see the cisco router redirecting the HTTP SYN packet for the internet website (from my client pc) to the cache. The Cache responds with a SYNACK with the source IP address "spoofed" to reflect the ip address of the actual webserver. However the PIX does not seem to forward it out the outside interface back to the router. Doing a debug ip packet on the DMZ interface of the PIX shows the packet entering the PIX. ANy help would be appreciated !! thanks. -Kartik | ||||||||||
| Similar Threads | Posted |
| WCCP v1 Cisco with cache on separate interface | March 24, 2006, 6:59 pm |
| WCCP - Cache engine - URL filter - how it all works? | November 23, 2006, 1:35 pm |
| Cisco 3750 and WCCP or PBR | October 11, 2006, 7:07 pm |
| Help with Cisco ASA w/CSC-SSM and WCCP Configuration.. | August 31, 2009, 7:09 pm |
| Cisco 1700 and DNS cache | July 18, 2005, 8:35 pm |
| Cache hits are low on a Cisco Content Engine | December 30, 2005, 1:03 pm |
| Putting Linux on Cisco 550 Cache Engine | August 9, 2006, 3:41 pm |
| Cisco 3750 Mac address cache size | June 5, 2008, 1:40 pm |
| Cisco Unity Express and Cisco CME GUI - separate admin accounts? | April 12, 2006, 10:33 pm |
| WAE- WCCP | April 26, 2008, 12:13 am |
| WAAS w/ WCCP not working | December 23, 2008, 10:05 am |
| passing wccp traffic via firewall | May 25, 2006, 11:04 am |
| WCCP on ASA & traffic between physical interfaces on ASA | February 13, 2007, 3:10 pm |
| vlan and arp cache | June 23, 2009, 9:18 pm |
| %IP-4-ZERO_ADDR: Zero MAC address for xxx.yyy.zzz.66 in ARP cache | November 27, 2006, 2:58 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
