Cisco Systems WAN packet loss/latency
Subject Author Date
WAN packet loss/latency bigbrorpi 04-24-06
Posted by on April 24, 2006, 9:23 pm
Hi -
I have a C3750 L3 switch connected to a C2950 via metro ethernet. The
2950 is at a remote site. There is a 2nd 2950 in parallel at the remote
site with another metro ethernet link as a backup to another 3750.
Users at the remote site alot of packet loss and excessive latency
(100ms+) when there a remote user is trying to pull a file from the
main site. It's cyclical and during nominal network activity, I end up
with normal 3-4ms ping times with an occasional 15ms ping time.
The two 3750s act as default gateways for the remote site running HSRP.
I cannot find the problem that is causing the latency. I do not see any
STP recalculations. I've tested both metro ethernet links (they're
different providers), and worked extensively with the providers and
found no circuit issues.
Can anyone think of any other things that might be causing these
issues?
Thanks
Posted by on April 24, 2006, 10:19 pm
Try a ping from the 2950 management address to each L3 hop to find out
which link is introducing the latency.
Ping to each of the HSRP real address, the virtual, the 3750 management
address, routers behind the 3750, etc.
This will assist you determining which link is yielding the latency.
Steve Griffin
www.blueconsole.com (Bluetooth Wireless Console Cable)
Similar ThreadsPosted
%PIX-4-402106: Rec'd packet not an IPSEC packet. August 25, 2006, 4:06 pm
packet of disconnect August 7, 2005, 10:52 pm
Packet fragmentation April 25, 2006, 3:07 pm
pix 7.21 packet-tracer July 7, 2006, 6:53 am
Packet fragmentation July 27, 2006, 3:28 pm
debug ip packet September 1, 2006, 7:56 pm
Packet Capture November 15, 2006, 7:39 am
Packet grabs April 9, 2007, 9:46 am
50% packet loss ? February 25, 2008, 1:00 pm
Packet Capturing July 4, 2008, 2:43 am
help: Packet over SONET sdh problem January 3, 2006, 12:40 pm
some commands about loss packet February 13, 2006, 8:33 am
WAN packet loss/latency April 24, 2006, 9:23 pm
per-packet load balancing July 20, 2006, 9:39 pm
Eigrp update packet November 26, 2005, 4:59 am
