Cisco Systems WAN Utilization Question
Subject Author Date
WAN Utilization Question mdargin 08-04-06
Posted by on August 4, 2006, 11:35 am
I have an application that performs 24 Mbyte transactions once per day.
I need to know how many kbps are needed on my WAN link to transfer 24
Mbytes of data?
How do I calculate the number of Kbps required for a 24 Mbyte
transaction?
We persently have 800 Kbit/sec partial T1 that uses on aver 600
Kbit/sec throughout the working day.
Any responses are greatly appreciated
Thank You
Posted by Walter Roberson on August 4, 2006, 12:17 pm
>Mbytes of data?
Ignoring overheads for the moment, you need to transfer 24 megabytes
and you need to have it finished before the transfer starts 24 hours
later. You therefore need an average throughput rate of at least
24 megabytes / 24 hours = 1 megabyte/hour . 1 hour is 3600 seconds,
so you need 1 megabyte / 3600 seconds. 1 megabyte is 8,000 kilobits,
so your rate must be at least 8,000 kilobits / 3600 seconds
which is about 2.2 kilobits / second.
Your actual needed rate will be higher than that, once some overheads
are taken into account, but it will still come out as less than 2.3
kilobits/second.
As you can tell from the above calculation, the necessary rate is
less than the round-off error in your usage rate.
You will not be able to use a full 800 Kbit/s on the link (overheads),
but if we arbitrarily say that you should be able to get 90% bandwidth
without difficulty, then you would have up to around 720 Kbit/s . If
you subtract the 600 Kbit/s already in use, your available bandwidth
is on the order of 120 Kbit/s, which is roughly 52 times faster than
you need to finish the task in time. The transfer should therefore
complete in less than half an hour during peak times, and less than
5 minutes off-peak.
Posted by Overlord on August 5, 2006, 4:42 pm
>>Mbytes of data?
First I want to compliment the excellent reply that was before this one.
To add to that, I would suggest looking into network traffic queues to help
out. QoS is what you need to look for now.
These are access-lists defining network traffic along with policies
declaring how much bandwith must be always allowed for or restricted for
certian access-list classes of network traffic. This would be helpful in
your situation where you would not want your application to overlord the
network connection yet still be guarenteed a certian amount of bandwidth in
order to complete.
Similar ThreadsPosted
WAN Utilization Question August 4, 2006, 11:35 am
Question on CPU utilization December 16, 2008, 11:59 am
Utilization May 20, 2006, 6:53 am
CPU utilization on the router. October 14, 2005, 5:37 pm
Monitoring WAN utilization July 25, 2007, 8:54 am
High CPU utilization on C3700 ??? October 18, 2005, 11:31 pm
Serial line - utilization December 15, 2005, 2:58 pm
bandwith utilization vs matrix February 13, 2006, 5:49 pm
Bandwidth Utilization for PIX Rookie February 27, 2006, 3:45 pm
1841-snmp-cpu-utilization July 6, 2005, 6:01 am
Best Tool to Display WAN utilization by the Second April 10, 2007, 9:34 am
6509 High Cpu Utilization November 30, 2007, 7:03 am
Router interface utilization June 12, 2008, 7:25 am
High CPU utilization on Cisco 1760 September 19, 2005, 1:59 am
DLSW Problem - Utilization High December 16, 2005, 2:02 am
