Cisco Systems WAN, Routing and Switching: Route some IP traffic over tunnel
Subject Author Date
WAN, Routing and Switching: Route some IP traffic over tunnel g18c 01-15-07
Posted by on January 15, 2007, 6:16 am
Hi, i would like to be able to route some internet trafic over my
normal adsl connection, and some other trafic (defined by port or ip
address) over a tunnel of some sort to a remote site, which would then
perform routing of its own.
Now i am totaly new to VPNs but would these work? Would we need to set
the internal network addresses to different subnets between the two
sites?
Are there other easier solutions for me to do this?
Many thanks,
Chris
Posted by www.BradReese.Com on January 15, 2007, 12:16 pm
Hi Chris,
You may wish to investigate the following online Cisco VPN Tutorials:
http://www.cisco.com/web/learning/le31/le46/products/products-security-vpn.html#vpn
Sincerely,
Brad Reese
2007 Cisco Salary Rates
http://www.bradreese.com/compensation-database.htm
Posted by on January 15, 2007, 1:50 pm
www.BradReese.Com wrote:
> Hi Chris,
Ok thanks, so VPN is the way to do it? I guess i need to make sure the
two sites subnets are different, failing that a simple NAT translation
would work quite well just before the VPN tunnel?
Cheers,
Chris
Similar ThreadsPosted
WAN, Routing and Switching: Route some IP traffic over tunnel January 15, 2007, 6:16 am
Cisco 5505 - routing traffic to outside interface, if VPN tunnel is down September 30, 2009, 12:49 pm
disable L2TP tunnel fast switching? September 3, 2006, 11:42 pm
Need to route SMTP traffic through static interface (not default route) March 27, 2007, 5:19 pm
Traffic shaping problems using switching module on 2811 January 21, 2006, 8:01 am
LAN, Switching and Routing: Cat 3524 switch better at streaming than 4503, why? December 12, 2007, 8:21 am
Internetworkexpert CCIE Routing & Switching Advanced Technologies Labs December 1, 2006, 3:15 am
LAN, Switching and Routing: Multicast advice needed on Cat 6513 IOS 12.2SXF5 February 7, 2008, 7:34 am
LAN, Switching and Routing: No link between fiber converter and Catalyst 6500, works with Router 7301 January 12, 2007, 2:27 am
Pix VPN-Tunnel Default Route? November 22, 2007, 8:15 am
Route traffice destined for 2 addresses/ips through vpn tunnel June 15, 2007, 11:22 am
PIX 7.0.4 tunnel all traffic. November 3, 2005, 12:27 pm
PIX 501 S2S VPN - Tunnel Up - No Traffic April 15, 2006, 11:44 am
*some* return traffic not going through vpn tunnel (although not all) December 20, 2005, 10:17 am
Process Switching vs. Fast/CEF Switching? May 27, 2007, 3:53 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
