Cisco Systems WAG54G LAN connection problem - help!
Subject Author Date
WAG54G LAN connection problem - help! max-man 07-11-05
Posted by max-man on July 11, 2005, 9:21 pm
I'm really stuck with trying to get my PC to talk to my WAG54G - can
anyone help please? Details as follows:
I've plugged my WAG54G into the built-in (and enabled) PCI Gigabit
LAN/high-speed on my Asus A7N8X-E motherboard using a straight through
RJ45 to RJ45 cable. I'm running Windows XP Pro. Note: I've also tried
the other built-in LAN port on the motherboard with the same results.
At this stage I'm assuming this LAN port is fully working as I have no
way to test it independently.
Note: the gateway is not connected to ADSL yet as I'm not yet on ADSL!
- at this stage I'm just trying to get the gateway to talk to the PC,
and I assume that an ADSL connection isn't essential to do this. Is
it?
Anyhow ......... I can't get the PC to permanently connect to the
gateway - at first it used to try and connect about once every minute,
its' main state (according to the tray icon) being the error
'A network cable is unplugged'
- but as mentioned, about once a minute it would try and connect to
the gateway, the relevant LAN port LED on the gateway would come on,
then the LED would go off, the network port would (very briefly!)
report:
'Acquiring network address'
I checked the troubleshooting section of the gateway manual and set
the TCP/IP settings as described (although I left the DNS settings
blank seeing as it's not connected to the 'net and hence doesn't have
a DNS address to enter).
Now though, despite changing those settings back to what they were
(after they failed to make any difference) it won't try and
automatically connect about once a minute. However, I CAN 'force' it
to try and connect by going into the Gigabit (a Marvell Yukon
88E8001/8003/8010) LAN cards' Advanced configuration settings and
change the 'Speed & Duplex' settings to, well, any value then I click
the 'Okay' button - in the Network Connections window the entry for
the Gigabit LAN connection will, for about a second or two, say
'Connected' BUT will then drop back to being 'Network cable
unplugged'. One difference though to before - the LAN connection LED
on the Gateway does NOT light up as it used to at first when it was
trying to connect automatically.
The gateways' Power LED constantly flashes too.
I've tried all the options in the troubleshooting section of the
gateway's manual but no joy.
I believe that I have the first release of the WAG54G, ie it's not V2.
Is this likely to be a problem with my LAN connection on the PC
motherboard or the gateway itself?
How can I verify which is causing the problem?
Thanks
Posted by on July 11, 2005, 2:58 pm
Log into your WAG54G using the web browser and make sure DHCP is
enabled. If it is, then see if you are getting ip address(ipconfig
/all). you should be getting a 192.168.1.x address with
s/m:255.255.255.0 Gateway should be your WAG54G ip address.(normally it
is 192.168.1.1) unless you have changed it. If you are getting IP
address from this router then you should be able to ping the gateway.
On XP go into network properties and TCP/IP settings and see if you
have it set to obtain ip address.
> it?
> report:
> Thanks
Posted by max-man on July 11, 2005, 10:26 pm
Thanks, but as the PC won't talk to the gateway I can't use my browser
to connect to it.
Yup, that's set correctly.
Posted by max-man on July 11, 2005, 9:56 pm
On Mon, 11 Jul 2005 21:21:21 GMT, max-man@hotmail.com (max-man) wrote:
One addition to that - the 'acquiring network address' error was
caused by my onboard NIC not having a MAC address assigned to it! This
has now been rectified but the PC still won't talk to the gateway -
basically everything in my original message still applies, except for
the 'acquiring network address' message.
Posted by Paul Womar on July 11, 2005, 10:14 pm
This probably isn't much help but I had almost exactly the same issue
with a Netgear GA302 PCI card connecting to, well, anything. It was
fine for months, then at about the time I updared to Win XP SP2 it
started acting as you decribed, sometimes endless fiddling with the
cables seemed to coax it into life, messing with Speed and Duplex would
often work too but a reboot would always stp it working again.
Eventually I gave up and bought an Intel card and it's back to all being
fine. I wonder if the chipset on your board is the same as the Netgear
card?
-> The email address used in this message *IS* valid <-
Similar ThreadsPosted
WAG54G LAN connection problem - help! July 11, 2005, 9:21 pm
Cisco Wireless-G WAG54G configuration problem July 13, 2005, 7:44 pm
Cisco 837 IPSEC Linksys WAG54g July 11, 2005, 5:37 pm
Linksys router WAG54G and updates of antispyware November 17, 2005, 11:25 pm
VPN SBC/ATT&T DSL connection problem November 1, 2006, 12:55 pm
VPN Connection thru ASA5500 Problem January 18, 2008, 5:35 am
mysterous connection problem for PIX 501 Networking June 6, 2006, 9:16 pm
problem with connection from inside to DMZ via global IP March 22, 2007, 9:35 am
Cisco ADSL connection problem May 7, 2007, 7:24 am
XP SP-2 Client VPN Connection thru PIX506E to W2K server Problem July 1, 2005, 3:01 pm
PIX 6.3 Site-toSite Connection - Just adding to crypto map problem November 15, 2007, 10:53 pm
Failover and Load balancing with 1 Cable connection and one T1 connection on Cisco 2801 router November 13, 2006, 2:23 pm
VPN site to site initial connection problem September 13, 2006, 1:18 am
VPN connection issue; no data passing after connection August 22, 2007, 11:37 am
Point to Point T1 connection problem September 25, 2008, 6:42 am
