Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by on August 14, 2005, 2:12 pm
Please log in for more thread options I have a static nat translation setup to allow the FTP service from outside to inside. This seems to work perfectly fine for a undetermined and seemingly random ammount of time. Then without warning it will stop allowing ftp communications. The only way to fix it is to take out the static mapping and put it in again, or to reboot the router. This is a very hard to solve problem for me because we have other static mappings on addresses on the router that work perfectly fine and never drop connections. The ftp server is an IIS ftp server if that has anything to do with it. The router also allows VPN connection in. I am just wondering if any of the experts hopefully reading this forum have any suggestions! Thanks. | |||||||||||||
Posted by Paul on August 14, 2005, 5:46 pm
Please log in for more thread options drstrangenorm@gmail.com wrote: | |||||||||||||
Posted by on August 24, 2005, 8:25 am
Nope, I am not doing any such thing. I am thinking about using a different ftp server program just to see if maybe the ftp program itself is sending goofy packets causing it to mess w/ the router. I doubt it, but at this point it is worth a shot. | |||||||||||||
Posted by RobO on August 24, 2005, 8:46 am
Hi, Are you using any sort of protocol inspection features on the router? What is the IOS, feature set you are using? Try using another ftp server and see if it happens again like you said to rule out either or. Then if it does the same thing post your config. Rob | |||||||||||||
Posted by on September 13, 2005, 11:21 am
Please log in for more thread options No not yet. I havent been able to go out and solve it because my
customer stopped paying the bills. I might get to go repo the servers :) If they pay the bill and I work on it and figure out a fix I'll let you know. | |||||||||||||
| Similar Threads | Posted |
| Very strange ftp problems through 1700 router. | August 14, 2005, 2:12 pm |
| Cisco 1700 Problems | November 17, 2005, 9:41 am |
| Two strange problems | August 24, 2006, 4:16 am |
| Cisco 1721 strange problems | July 14, 2005, 10:32 am |
| A non-Cisco router, BDCOM 1700 Router Series | June 28, 2008, 4:27 am |
| Cisco 1700 Router | July 25, 2008, 8:00 am |
| how to stop denial of service in a 1700 router | September 2, 2005, 6:09 pm |
| 1700 Router - creating a dot1q VLAN subinterface | July 5, 2007, 9:49 pm |
| Re: Strange Router behaviour | June 14, 2008, 1:45 pm |
| cant ping when adding secondary ip to 1 fastethernet interface on 1700 router | August 17, 2005, 12:14 pm |
| Strange Cisco Router/VPN situation | September 7, 2005, 3:20 pm |
| configuration of a router Cisco 1700 on ADSL max of a wide-area network | February 10, 2006, 4:49 am |
| VPN problems, PIX and Router | September 1, 2005, 8:18 pm |
| 837 Router problems | June 22, 2005, 1:19 pm |
| installing SDM on an 877 DSL router ... having RCP problems ... | March 7, 2006, 11:13 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> the router.
> Thanks.
