Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Merv on June 5, 2008, 3:32 pm
Please log in for more thread options Are you using a Cisco VPN client - if so what version ? Do you know what the equipment that you connect to a t the other end is ? If you are getting a succesful connection then your PC should be given an IP address assignment by the VPN server - depending on the VPN lcient you should be able to display that Also you should tale a lookat your PC routing table before and after making the VPN connection using the DOS cmd route print - you should see that the default route changes after the connection is made - is that occuring | |||||||||||||
Posted by walterbyrd on June 19, 2008, 3:46 pm
Please log in for more thread options Similar problem, different VPN client. I am now trying Juniper's VPN client. This time, I can not even log in. I am told I need to have port 500 open. But I am using comcast, and that port seems to be closed. I downloaded a free utility called "Advanced Port Scanner 1.3." According to this utility, the only ports I have open are: 25, 80, 135, 139, and 445. I called comcast, and comcast assured me that comcast does not block VPN traffic. Comcast told me that the only ports that comcast blocks are 67, 68, 135, 137,138,139,445,512,520,1080. I tried telnetting to port 500, and got this: >telnet localhost 500
Connecting To localhost...Could not open a connection to host on port
500 : Connect failed | |||||||||||||
Posted by News Reader on June 19, 2008, 5:26 pm
Please log in for more thread options walterbyrd wrote:
> I tried telnetting to port 500, and got this: > >> telnet localhost 500
> 500 : Connect failed Walter: Keep in mind that I'm only seeing your post, and not those preceding it (deleted per my subscription settings). Is the result not what you would expect given that ISAKMP is on "UDP" port 500, and Telnet uses TCP? TCP port 500 would not be open. Best Regards, News Reader | |||||||||||||
VPN dial connects, but does not work
Yahoo!
Windows Live
del.icio.us
digg
Netscape
