Cisco Systems VLAN Question
Subject Author Date
VLAN Question tdenham735 07-25-07
Posted by on July 25, 2007, 12:41 pm
I have always setup VLAN's using a Cisco Switch and Router, however
I'm hearing that it's possible to setup a 3560 Switch with multiple
VLAN's and also route between the VLAN's.
Is this true or do I still need a Cisco Router?
My guess is that I still need the router.
Thanks in advance!
Posted by on July 25, 2007, 12:58 pm
> Thanks in advance!
Just as a followup, I see that some switches will do L3 routing and a
separate module is needed. Would this be a software module to allow
"ip enable routing"?
Currently if I enter "ip enable routing" it's not a valid command on
the 3560.
Thanks again:)
Posted by Chris on July 25, 2007, 1:15 pm
>> Thanks in advance!
> the 3560.
> Thanks again:)
I think that the 3560 switch only allows one active layer3 vlan interface,
usually used for management so you would have to trunk vlans to a router to
route between them.
The command is 'ip routing', not 'ip enable routing'
Chris.
Posted by Lovejoy on July 25, 2007, 1:15 pm
> > Thanks in advance!
> the 3560.
> Thanks again:)
You can set up vlans on just about any Cisco switch, and can "switch"
or route between them (intra-vlan routing)....
http://www.cisco.com/en/US/tech/tk389/tk815/tk857/tsd_technology_support
_sub-protocol_home.html
depending on the IOS image. The command to enable routing in IOS is ip
routing.
Lovejoy
This space for lease....
Posted by on July 25, 2007, 1:23 pm
> > > Thanks in advance!
> > the 3560.
> > Thanks again:)
> routing.
> Lovejoy
Brain stink...I meant "ip routing":(
Seems I need to setup for intra-vlan routing. The link above was
broke, or else required special access, however I did find this:
http://www.cisco.com/en/US/docs/switches/lan/catalyst5000/hybrid/routing.html
Seems like this is what I need to do.
Thanks much Lovejoy!!!
Similar ThreadsPosted
Vlan and PIX question March 28, 2006, 11:16 am
Cat OS VLAN question July 7, 2006, 6:32 pm
VLAN Question March 8, 2007, 3:06 pm
VLAN Question July 25, 2007, 12:41 pm
VLAN Question August 22, 2007, 3:01 pm
vlan and vpn config question January 12, 2006, 10:04 am
basic vlan pix 6.3 question July 25, 2006, 2:26 am
Basic VLAN question. June 27, 2005, 12:21 pm
Native VLAN question November 22, 2005, 5:58 am
newbie's question on VLAN September 15, 2006, 12:40 pm
VLAN IP Addressing Question November 14, 2006, 10:32 am
question of vlan cisco March 3, 2007, 12:36 am
VLAN basic question March 2, 2007, 10:40 am
dot1q vlan question March 21, 2007, 10:18 pm
native vlan question April 15, 2008, 3:51 am
