Cisco Systems Using IPv6 on a Cisco 877W
Subject Author Date
Using IPv6 on a Cisco 877W Matthias Scheler 10-21-06
Posted by Matthias Scheler on October 21, 2006, 10:52 am
    Hello,
I'm trying to configure IPv6 on a Cisco 877W. According to all documents
I can find via Google both the hardware and the IOS (12.4(4)T4 in this
case) should support IPv6. But the machine doesn't know the "ipv6" command
nevertheless.
What am I doing wrong?
    Kind regards
Matthias Scheler                                  http://zhadum.org.uk/
Posted by arne on October 21, 2006, 12:39 pm
On Sat, 21 Oct 2006 14:52:11 +0000, Matthias Scheler wrote:
in conf mode he doesn't know "ipv6 unicast-routing"? you have to enter
this first before you can give ipv6 addresses to interfaces
arne
Posted by Matthias Scheler on October 21, 2006, 12:43 pm
No, I already tried that. It doesn't accept the command:
jumpgate(config)#ipv6 unicast-routing
% Invalid input detected at '^' marker.
    Kind regards
Posted by www.BradReese.Com on October 21, 2006, 4:20 pm
Hi Matthias,
You may wish to investigate the Cisco 877W Config Wizard:
http://www.ifm.net.nz/cookbooks/800-isr-wizard.html
Sincerely,
Brad Reese
BradReese.Com - Cisco Repair
http://www.bradreese.com/cisco-big-iron-repair.htm
1293 Hendersonville Road, Suite 17
Asheville, North Carolina  USA 28803
USA & Canada:  877-549-2680
International: 828-277-7272
Fax: 775-254-3558
AIM: R2MGrant
BradReese.Com - Cisco Power Supply Headquarters
http://www.bradreese.com/cisco-power-supply-inventory.htm
Posted by Matthias Scheler on October 22, 2006, 5:35 am
    tron@zhadum.org.uk (Matthias Scheler) writes:
I found out my my 877W doesn't support IPv6 in the meantime:
Despite the fact that the dealer who sold the Cisco to me lists
"IPv6 support" as one of the features it is included in IOS image.
The Cisco 877W-G-E-K9 only provides "Advanced Security Options"
but not "Advanced IP Services" by default.
"Advanced IP Services" can be purchased seperately and requires
a larger flash memory.
    Kind regards
Similar ThreadsPosted
Using IPv6 on a Cisco 877W October 21, 2006, 10:52 am
NAT type of Cisco 877W November 26, 2005, 8:14 pm
Bridging with a Cisco 877W December 21, 2006, 1:11 pm
Cisco 877W of 857W ? May 23, 2008, 10:28 am
Cisco 877W and Demon November 22, 2008, 9:39 am
Problem config Cisco 877w October 26, 2005, 5:02 am
Cisco 877W Router ( Newbie ) November 3, 2005, 7:28 pm
Upgrading flash in a Cisco 877W October 27, 2006, 5:31 am
Cisco 877W as Wireless client July 1, 2007, 12:49 pm
problem with wireless on a Cisco 877W March 5, 2009, 5:46 pm
Cisco 877W, fixed IP, ISP connection drops June 30, 2006, 2:37 am
Cisco 877W shows incorrect DSL attenuation July 3, 2006, 7:26 pm
Bridging Ethernet and WLAN with a Cisco 877W October 29, 2006, 4:05 pm
Figuring out A-DSL link uptime on a Cisco 877W January 11, 2007, 6:42 am
Cisco 877w: Fa0-3 Interfaces up but no traffic passes August 17, 2007, 6:55 pm
Latest PostsForumRSS
NEWS: Samsung takes on the Apple iPad with the 7 inch Galaxy... Wireless Networking
c3560 port configuration Cisco Systems
Broadband 2010: A Big Slowdown [telecom] General Telecommunications Forum
Control Hot Water Circ Pump With X10? General Home Automation
Official Course CCNP TSHOOT 642-832 / Foundation Learning Gu... Cisco Certification
Speedflow Communications Honored for Innovation Voice-Over-IP
USB _to_ RJ45 (not from) connection Ethernet LAN
FAQ: Maximizing cable modem or DSL speed Cable Modems
CASH FOR CISCO - I BUY USED AND NEW EQUIPMENT & LOTS MOR... Telecom Technical
FAQ: Maximizing cable modem or DSL speed Digital Subscriber Line
How to set up Meridian 1 to "provide clock" to a C... Nortel Networks
New Discovery about WDM LAN and Telecom Cabling
Control Hot Water Circ Pump With X10? Home Automation
Text file to automate restoring a dropped VPN connection. Virtual Private Networks
Home Theater Installation Home Theater
Re: The Turkic Languages in a Nutshell Fiber Optics
sip Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Click Here to learn more
