Posted by Scott Townsend on April 2, 2007, 5:46 pm
So I'm looking to update my 4500M.
The 'sh ver' says:
cisco 4500 (R4K) processor (revision B) with 32768K/16384K bytes of memory.
128K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
4096K bytes of processor board Boot flash (Read/Write)
The IOS I'm looking to download says
Min. Memory(MB) 32
Min. Flash 8
Image c4500-i-mz.122-40a.bin
So waht is the 32/16meg
does the two 4megs = 8?
Thanks,
Scott<-
Posted by on April 2, 2007, 8:00 pm
> The 'sh ver' says:
> Min. Memory(MB) 32
> Min. Flash 8
> Thanks,
> Scott<-
Most likely 4.
Some of the older high end routers (and yes the 4500M
was highish end) had a seperate "boot helper" image and
operational image.
The boot flash is quite likely for the boot helper.
the 32/16 is Total-RAM/io-ram, or is the total 48?
Whatever, its the same for brand new kit so just look it up.
| Similar Threads | Posted |
| Updating IOS, how much Flash do I have? | April 2, 2007, 5:46 pm |
| Updating flash on 3620 - again | August 11, 2005, 8:25 am |
| updating pix IDS signitures | October 8, 2007, 12:23 pm |
| updating pix 506e? | June 9, 2008, 5:47 pm |
| Updating 2620 & 2924 FW | September 16, 2007, 9:33 pm |
| Updating 2900 switch | September 26, 2007, 9:32 pm |
| IOS Updating my hosts entries?? | October 9, 2007, 8:26 pm |
| Issues Updating CiscoWorks Inventory | February 8, 2006, 6:26 am |
| VPN 3005 Error updating group for LAN-to-LAN connection (Too Many Entries Error. Delete an entry before adding a new one). | August 25, 2006, 2:25 am |
| dir, del flash: | October 15, 2007, 7:51 pm |
| 20 MB flash on 1600R ? | July 10, 2006, 7:24 pm |
| AP of the 881 does not see usb flash memory | November 17, 2009, 4:09 pm |
| cisco 828 flash file | August 11, 2005, 10:05 pm |
| Renaming files in the flash. | August 17, 2005, 5:08 pm |
| 3600 RAM and Flash Uopgrade | November 23, 2005, 11:37 pm |
> The 'sh ver' says:
> Min. Memory(MB) 32
> Min. Flash 8
> Thanks,
> Scott<-
