Posted by ttripp on April 29, 2009, 11:58 am
I am trying to use ip sla with icmp-echo to control the entry of a
static
route in the routing table. Currently I am using sla for controling
two routes, with more
to come. My sla configuration looks like this:
ip sla monitor 5
type echo protocol ipIcmpEcho 10.120.26.5 source-ipaddr 10.120.26.60
frequency 15
ip sla monitor reaction-configuration 5 threshold-falling 5000
threshold-type consecutive
3
ip sla monitor schedule 5 life forever start-time now
ip sla monitor 12
type echo protocol ipIcmpEcho 10.120.26.12 source-ipaddr 10.120.26.60
frequency 15
ip sla monitor reaction-configuration 12 threshold-falling 5000
3
ip sla monitor schedule 12 life forever start-time now
! Lines ommited
track 5 rtr 5 reachability
track 12 rtr 12 reachability
! Lines omitted
ip route 10.100.30.0 255.255.255.0 10.120.26.5 track 5
ip route 10.1.3.12 255.255.255.255 10.120.26.12 track 12
As I understand it, the way I have this configured the router should
ping the two
configured ip addresses every 15 seconds, and if the 5000msec
threshold is surpassed three
consecutive times, then reachability is considered "down" and the
router is removed from
my table.
The problem is that I get the following log messages at random times:
04-29-2009 10:00:23 Paris_-_WAN-PARIS-1_(10.60.10.1) 182: *Apr 29
14:13:00:
%TRACKING-5-STATE: 12 rtr 12 reachability Down->Up
04-29-2009 10:00:13 Paris_-_WAN-PARIS-1_(10.60.10.1) 181: *Apr 29
14:12:50:
%TRACKING-5-STATE: 12 rtr 12 reachability Up->Down
However, monitoring from PRTG shows the ping response times for both
of these ip addresses
is in the 100-200msec time, which shouldn't be nearly enough to
trigger a Down->Up.
Also, each Down->Up is followed exactly 10 seconds later by an Up-
>Down. This
happens each and every time. I have four other routers configured the
same way and they
also have the same issue, and the same 100-200msec ping time, and the
same 10 second
Down->Up/Up->Down cycle.
Bandwidth utilization on the circuits these pings are going out on
varies, but the error
is generated even when traffic is nill.
So, has anyone seen anything like this before? Thanks.
Posted by bod43 on April 30, 2009, 12:59 am
> static
> route in the routing table. =A0Currently I am using sla for controling
> to come. =A0My sla configuration looks like this:
> ip sla monitor 5
<..snipped..>
> same 10 second
The Down->Up seems back to front to me?
Surely it is up normally and needs to go Up-> down first?
You might consider
debug ip sla event
debug ip sla error
to see what the router thinks it is doing.
These will generate quite a bit of output over time.
Posted by Thrill5 on April 30, 2009, 1:30 am
Please log in for more thread options I believe that the problem is the you have configured a 5 second timeout,
and your only polling every 15 seconds. The falling-threshold of 5000 msec
(5 seconds) means that if the last successful ping occured more than 5
seconds ago, the sla is down. This number is NOT how long it should wait
for a response.
> static
> ip sla monitor 5
> frequency 15
> 3
> ip sla monitor 12
> frequency 15
> 3
> ! Lines ommited
> ! Lines omitted
> ping the two
> my table.
> 14:13:00:
> 14:12:50:
> trigger a Down->Up.
>>Down. This
> same way and they
> same 10 second
Posted by ttripp on May 1, 2009, 8:58 am
> and your only polling every 15 seconds. =A0The falling-threshold of 5000 msec
> seconds ago, the sla is down. =A0This number is NOT how long it should wait
> for a response.
> > static
> > ip sla monitor 5
> > frequency 15
> > 3
> > ip sla monitor 12
> > frequency 15
> > 3
> > ! Lines ommited
> > ! Lines omitted
> > ping the two
> > my table.
> > 14:13:00:
> > 14:12:50:
> > trigger a Down->Up.
> >>Down. =A0This
> > happens each and every time. =A0I have four other routers configured the
> > same way and they
> > same 10 second
> > So, has anyone seen anything like this before? =A0Thanks.- Hide quoted text -
> - Show quoted text -
Thanks. I opened a ticket with TAC and they said the same thing,
basically. It's fixed now.
| Similar Threads | Posted |
| Up->Down messages related to ip sla icmp-echo when there are no apparent network issues | April 29, 2009, 11:58 am |
| Network performance issues with 3500XL | February 9, 2006, 4:50 am |
| Why am I a t**t? PIX related incident! | November 2, 2005, 3:46 pm |
| Diagnostic IPSec-related IOS command | October 4, 2005, 6:14 am |
| VOIP at home (not Cisco related) | December 1, 2005, 5:44 am |
| Weird traffic problem - might be PIX 520 related. | February 2, 2007, 4:53 am |
| changed state to up changed state to down FastEthernet LINEPROTO-5-UPDOWN | March 7, 2007, 9:37 am |
| Can PIM-dense mode and PIM sparse Mode exchange routing related information | December 13, 2007, 4:30 am |
| %PIX-4-106023 messages in log | November 30, 2005, 11:55 am |
| PIX failover and hello messages | November 19, 2005, 8:40 am |
| Unity messages late? | August 4, 2005, 11:03 am |
| How do I translate ALL WebVPN messages | May 2, 2006, 4:02 am |
| PIX 501 SNMP trap messages | May 3, 2007, 2:09 am |
| Cisco 837 & Syslog. Where's the messages. | May 14, 2007, 11:45 am |
| Error messages coming from WLC | November 10, 2008, 9:54 am |
