Cisco Systems Two 3825s won't talk to each other
Subject Author Date
Two 3825s won't talk to each other BigDaveKelly@googlemail.com 07-10-08
Posted by BigDaveKelly@googlemail.com on July 10, 2008, 6:23 am
We have two 3825s, and I'm struggling to get them to talk to each
other. Interface GigabitEthernet0/0/0 (A HWIC-1GE-SFP with a
1000Base-T SFP) on each router is connected to the other with a
tested straight cable - changing it to crossover makes no
difference.
router1:
interface GigabitEthernet0/0/0
description Connection to router2
ip address 10.0.0.1 255.255.255.252
negotiation auto
router2:
description Connection to router1
ip address 10.0.0.2 255.255.255.252
negotiation auto
And a bit of output showing the line is up:
router1#show ip interface brief | include 0/0/0
GigabitEthernet0/0/0 10.0.0.1 YES manual up
down
router2#show ip interface brief | include 0/0/0
GigabitEthernet0/0/0 10.0.0.2 YES manual up
down
Now the problem - neither router can ping each other, and even though
I
believe these should show up as connected routes, they do not:
router2#show ip route | include 10.0.0
router2#
router1#show ip route | include 10.0.0
router1#
Can anyone let me know if there's anything else I can provide that
will help, or ideally tell me what I'm doing wrong?
Posted by Trendkill on July 10, 2008, 7:32 am
On Jul 10, 6:23=A0am, "BigDaveKe...@googlemail.com"
> other. =A0Interface GigabitEthernet0/0/0 (A HWIC-1GE-SFP with a
> difference.
> router1:
> =A0 description Connection to router2
> =A0 ip address 10.0.0.1 255.255.255.252
> =A0 negotiation auto
> router2:
> =A0 description Connection to router1
> =A0 ip address 10.0.0.2 255.255.255.252
> GigabitEthernet0/0/0 =A0 =A0 =A0 10.0.0.1 =A0 =A0 =A0YES manual up
> =A0 =A0 =A0down
> GigabitEthernet0/0/0 =A0 =A0 =A0 10.0.0.2 =A0 =A0 =A0YES manual up
> =A0 =A0 =A0down
> I
> router2#
> router1#
First, I think you need a crossover (unless its a switch module in the
router). Second, have you tried hard-setting the speed/duplex?
Posted by BigDaveKelly@googlemail.com on July 10, 2008, 9:01 am
> > difference.
As above, I've tried both a crossover and a straight cable. The
interfaces should be able to do Auto MDIX so work with a straight
cable.
The speed/duplex can't be hard set on the HWIC-1GE-SFP - both are set
to negotiation auto by requirement.
Posted by Trendkill on July 10, 2008, 9:09 am
On Jul 10, 9:01=A0am, "BigDaveKe...@googlemail.com"
> > > difference.
> > router). =A0Second, have you tried hard-setting the speed/duplex?
> As above, I've tried both a crossover and a straight cable. =A0The
> cable.
add 'media-type rj45' to the interface configs.
Posted by BigDaveKelly@googlemail.com on July 10, 2008, 9:23 am
I'm afraid not; that's another command that's not available on this
interface.
Thanks for your suggestions! Keep 'em coming!
Similar ThreadsPosted
Two 3825s won't talk to each other July 10, 2008, 6:23 am
NAT ~ when two computers with same IP talk? August 19, 2007, 4:38 pm
ubr924 modem does not want to talk through its ethernet0 port June 7, 2006, 8:32 am
VPN clients unable to talk to internal networks January 11, 2008, 2:22 pm
Getting router to talk to client subnet/VLAN August 23, 2008, 4:33 pm
CSS 11503 Gig over Copper Ports - Talk to Fast Ethernet? August 15, 2006, 12:23 pm
877W - cannot talk wireless device to wireless device October 30, 2005, 3:35 am
