Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Christer Bergstrom on July 9, 2005, 10:35 am
Please log in for more thread options I have an Cisco 837 where the CRWS-interface goes into an infinite loop when trying to configure the 837 to my ISP. They have recently removed login with username/password, so I tried to let the 837 via the CRWS-interface findout the config parameters via Quick-setup, then the infinite loop starts. If I monitor the 837 through consol, I can se that it starts with someting. sh ver for my 837: Cisco Internetwork Operating System Software IOS (tm) C837 Software (C837-K9O3SY6-M), Version 12.2(13)ZH2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Synched to technology version 12.2(14.5)T TAC Support: http://www.cisco.com/tac Copyright (c) 1986-2003 by cisco Systems, Inc. Compiled Tue 22-Jul-03 09:28 by ealyon Image text-base: 0x800131E8, data-base: 0x80B50C04 ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1) ROM: C837 Software (C837-K9O3SY6-M), Version 12.2(13)ZH2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) Router uptime is 44 minutes System returned to ROM by power-on System image file is "flash:c837-k9o3sy6-mz.122-13.ZH2.bin" CISCO C837 (MPC857DSL) processor (revision 0x500) with 44237K/4915K bytes of memory. Processor board ID AMB08191KCX (3757405852), with hardware revision 0000 CPU rev number 7 Bridging software. 1 Ethernet/IEEE 802.3 interface(s) 1 ATM network interface(s) 128K bytes of non-volatile configuration memory. 12288K bytes of processor board System flash (Read/Write) 2048K bytes of processor board Web flash (Read/Write) Configuration register is 0x2102 sh run shows: Current configuration : 881 bytes ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname Router ! logging queue-limit 100 ! ip subnet-zero ip dhcp excluded-address 10.10.10.1 ! ip dhcp pool CLIENT import all network 10.10.10.0 255.255.255.0 default-router 10.10.10.1 lease 0 2 ! ! ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! ! ! ! ! ! interface Ethernet0 ip address 10.10.10.1 255.255.255.0 hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive dsl operating-mode auto ! ip classless ip http server no ip http secure-server ! access-list 23 permit 10.10.10.0 0.0.0.255 ! line con 0 exec-timeout 120 0 no modem enable stopbits 1 line aux 0 stopbits 1 line vty 0 4 access-class 23 in exec-timeout 120 0 login local length 0 ! scheduler max-task-time 5000 ! end As the CRWS-interface went into an loop and as I am not so familiar with Cisco-router setup, I would be wery grateful if somebody would take some of their time to help me with this task, I have seen some configs in this group, but they all applies to username/password login to ISP. best regards Christer Bergström Viker Sweden | |||||||||||||
Posted by BradReeseCom on July 9, 2005, 11:15 am
Please log in for more thread options These Cisco 837 Config Wizards may or may not help you: http://www.ifm.net.nz/cookbooks/configwizard.html as well as http://www.ifm.net.nz/cookbooks/ipv6configwizard.html Sincerely, Brad Reese BradReese.Com Cisco Repair Service Experts 1293 Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 U.S. Toll Free: 877-549-2680 International: 828-277-7272 Website: http://www.bradreese.com/cisco-big-iron-repair.htm | |||||||||||||
Posted by Christer Bergstrom on July 10, 2005, 2:12 pm
skrev: Hello I have now an config like this: version 12.2 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname Router ! logging queue-limit 100 ! ip subnet-zero ip dhcp excluded-address 192.168.0.1 ip dhcp excluded-address 195.67.199.9 ! ip dhcp pool balja network 192.168.0.0 255.255.255.0 default-router 192.168.0.1 dns-server 195.67.199.9 195.67.199.10 ! ! ip audit notify log ip audit po max-events 100 no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface Ethernet0 ip address 192.168.0.1 255.255.255.0 ip nat inside hold-queue 100 out ! interface ATM0 no ip address no atm ilmi-keepalive pvc 8/35 encapsulation aal5snap ! dsl operating-mode auto bridge-group 1 ! interface BVI1 ip address dhcp client-id Ethernet0 ip nat outside ! ip nat inside source list 1 interface BVI1 overload ip classless ip route 0.0.0.0 0.0.0.0 BVI1 ip http server no ip http secure-server ! access-list 1 permit 0.0.0.1 255.255.255.0 bridge 1 protocol ieee bridge 1 route ip ! line con 0 exec-timeout 120 0 no modem enable stopbits 1 line aux 0 stopbits 1 line vty 0 4 access-class 23 in exec-timeout 120 0 login local length 0 ! scheduler max-task-time 5000 ! when executing sh arp, it gives this: Protocol Address Age (min) Hardware Addr Type Interface Internet 81.226.72.239 7 0002.3b00.d94b ARPA BVI1 Internet 192.168.0.119 1 0006.5b57.4731 ARPA Ethernet0 Internet 81.226.84.203 - 0000.0c46.2a10 ARPA BVI1 Internet 192.168.0.1 - 000f.8f60.c97d ARPA Ethernet0 Internet 81.226.67.77 2 0002.3b00.d94b ARPA BVI1 It indicates some connection to the outside. Where am I wrong in the configuration? best regards Christer Bergström Viker Sweden | |||||||||||||
Posted by Brian V on July 10, 2005, 8:56 am
> skrev:
> >>Hi Christer,
>> >>These Cisco 837 Config Wizards may or may not help you: >> >>http://www.ifm.net.nz/cookbooks/configwizard.html >> >>as well as >> >>http://www.ifm.net.nz/cookbooks/ipv6configwizard.html >> >>Sincerely, >> >>Brad Reese >>BradReese.Com Cisco Repair Service Experts >>1293 Hendersonville Road, Suite 17 >>Asheville, North Carolina USA 28803 >>U.S. Toll Free: 877-549-2680 >>International: 828-277-7272 >>Website: http://www.bradreese.com/cisco-big-iron-repair.htm >
> Hello > I have now an config like this: > > version 12.2 > no service pad > service timestamps debug datetime msec > service timestamps log datetime msec > service password-encryption > ! > hostname Router > ! > logging queue-limit 100 > ! > ip subnet-zero > ip dhcp excluded-address 192.168.0.1 > ip dhcp excluded-address 195.67.199.9 > ! > ip dhcp pool balja > network 192.168.0.0 255.255.255.0 > default-router 192.168.0.1 > dns-server 195.67.199.9 195.67.199.10 > ! > ! > ip audit notify log > ip audit po max-events 100 > no ftp-server write-enable > ! > ! > ! > ! > ! > bridge irb > ! > ! > interface Ethernet0 > ip address 192.168.0.1 255.255.255.0 > ip nat inside > hold-queue 100 out > ! > interface ATM0 > no ip address > no atm ilmi-keepalive > pvc 8/35 > encapsulation aal5snap > ! > dsl operating-mode auto > bridge-group 1 > ! > interface BVI1 > ip address dhcp client-id Ethernet0 > ip nat outside > ! > ip nat inside source list 1 interface BVI1 overload > ip classless > ip route 0.0.0.0 0.0.0.0 BVI1 > ip http server > no ip http secure-server > ! > access-list 1 permit 0.0.0.1 255.255.255.0 > bridge 1 protocol ieee > bridge 1 route ip > ! > line con 0 > exec-timeout 120 0 > no modem enable > stopbits 1 > line aux 0 > stopbits 1 > line vty 0 4 > access-class 23 in > exec-timeout 120 0 > login local > length 0 > ! > scheduler max-task-time 5000 > ! > > when executing sh arp, it gives this: > > Protocol Address Age (min) Hardware Addr Type Interface > Internet 81.226.72.239 7 0002.3b00.d94b ARPA BVI1 > Internet 192.168.0.119 1 0006.5b57.4731 ARPA Ethernet0 > Internet 81.226.84.203 - 0000.0c46.2a10 ARPA BVI1 > Internet 192.168.0.1 - 000f.8f60.c97d ARPA Ethernet0 > Internet 81.226.67.77 2 0002.3b00.d94b ARPA BVI1 > > It indicates some connection to the outside. > > Where am I wrong in the configuration? > > best regards > Christer Bergström > Viker > Sweden > Your NAT acl is messed up, your only allowing deices with X.X.X.1 addresses to be nated (which in your subnet is only your ethernets interface). conf t no access-list 1 permit 0.0.0.1 255.255.255.0 access-list 1 permit 192.168.0.0 0.0.0.255 exit wr mem -Brian | |||||||||||||
| Similar Threads | Posted |
| Trying to connet to Telia(Skanova) ADSL provider in Sweden with 837 | July 9, 2005, 10:35 am |
| Connected to Telia/Skanova using 837 but with oddities | July 24, 2005, 9:06 pm |
| Cannot establish connection with ADSL provider | December 4, 2005, 4:12 pm |
| Reliability of Provider | July 23, 2005, 1:50 am |
| Obtain DNS Information from Provider | April 26, 2006, 5:00 pm |
| QOS VOIP - Hosted IP PBX Provider | July 4, 2008, 11:04 am |
| Linksys VoIP boxes NOT tied to a particular provider? | February 13, 2006, 11:28 am |
| Service Provider Bandwidth Test MPLS Network | July 9, 2007, 9:47 am |
| Catalyst 3750-METRO as MPLS Provider Core | July 8, 2008, 6:39 pm |
| Config for cisco 1841 with one adsl for internet and one adsl for vpn | October 29, 2006, 3:31 am |
| Multiple network/Multiple provider Routing | May 23, 2007, 10:56 am |
| voip over adsl? | August 27, 2005, 2:09 am |
| VPN with 800 series ADSL | January 19, 2006, 5:22 am |
| 877 adsl capacity | April 2, 2006, 3:59 pm |
| QoS on an ADSL connection | April 13, 2006, 10:05 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>as well as
>Sincerely,
>Brad Reese
