Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by brickwalls19 on July 14, 2006, 1:45 pm
user environment. I would need to take a total of all our Catalyst switch ports and find the number of used and unused ports. Is there a perl script or app that will be able to help gather this information? It seems tedious to log into every switch, get a 'show port status' output, and export it to an Excel spreadsheet. This report would probably need to be done every month to track the changes in the server and user environment. Thanks. | |||||||||||||
Posted by Walter Roberson on July 14, 2006, 2:19 pm
Please log in for more thread options queries using SNMP. But first you have to define what a "used" port is and an "unused port" is. It turns out to be a difficult question, once you start thinking about people turning off systems, people going on vacation, systems that are plugged in but unusued, systems that simply haven't had anything to say for awhile. The investigation gets noticably harder if you have some hubs or unmanaged switches. If your network staff doesn't already do the kind of tracking necessary for the above, chances are usually fairly high that someone has installed an unauthorized switch because ~$20 is a lot cheaper and faster than getting another authorized jack installed. | |||||||||||||
Posted by brickwalls19 on July 20, 2006, 10:55 am
Please log in for more thread options on the instance i do a 'show port status'connected = used port not connected = unused port Walter Roberson wrote: | |||||||||||||
Posted by J on July 20, 2006, 4:56 pm
Please log in for more thread options brickwalls19 wrote:That's fine and dandy if you want stats for that exact moment in time, say 09:00. But what about the group of call center people that don't come in until 13:00? There's another couple of dozen ports that may be disconnected when you check the status. Don't forget about the executive golf tournament, I mean business retreat that the upper crust happen to be gone to this week. There's another 4 dozen ports. Is there a bad case of flu going through the office? There's another large group of machines that are offline. The point is port status means very little if you aren't checking and logging the status of each individual port over a lengthy period of time. If you want to get anything accurate you should instead look at port statistics. Go through your interface statistics and look for ports that actually have carried Ethernet frames. Any ports that have been used since your last interface counter clearing will show that they've carried frames, even if the ports are currently offline. When you're done clear the counters. Do the same thing next week. Note any changes. This is as close as you can get to accurate port counts. Even this is not fool-proof. What about the extra ports in the conference room that are only used once a quarter to hookup all the misc AV equipment for the quarterly report, or the 3 dozen ports in the large storage room that gets cleaned out once a year and used for 3 weeks worth of training? J | |||||||||||||
Posted by Walter Roberson on July 20, 2006, 8:46 pm
Please log in for more thread options Thanks, you saved me a lot of typing along the same vein ;-) | |||||||||||||
| Similar Threads | Posted |
| Switch port consumption report and capacity planning. | July 14, 2006, 1:45 pm |
| Internet Bandwidth Capacity Planning | November 24, 2006, 9:08 pm |
| Unused switch port report for 1/3 months | September 3, 2008, 10:42 am |
| 6509 power consumption | January 24, 2006, 8:07 pm |
| 877 adsl capacity | April 2, 2006, 3:59 pm |
| WLAN Planning | January 19, 2007, 2:02 pm |
| Port mirroring in HP 2626-pwr 24 port switch | October 25, 2005, 5:01 am |
| Change routing port to switch port | March 5, 2008, 4:53 am |
| How to get a report of VPN connections on a PIX | July 25, 2007, 9:40 am |
| How to report bugs to Cisco | October 25, 2009, 7:17 am |
| How to avoid filtered status report - PIX. | June 20, 2005, 6:05 pm |
| Switch port | December 14, 2005, 12:09 am |
| switch port going up and down on specific NIC | October 12, 2006, 9:47 am |
| Problem with Cisco Switch Port Please Help | August 23, 2005, 12:43 pm |
| Filter Switch Port Traffic? | February 11, 2009, 10:00 pm |
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language! Click Here to learn more |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
