Cisco Systems Switch Issues
Subject Author Date
Switch Issues Daniel 03-10-06
Posted by Daniel on March 10, 2006, 6:01 pm
I have a weird issue. I have 4 or 5 switches (all different makes) and
intermittently they drop all network traffic. They don't lose power but just
drop all traffic. They don't even do it at the same time. There is no
consistency.
Any ideas would be greatly appreciated!
Thanks
Posted by Merv on March 11, 2006, 5:45 am
You have to provide a LOT more info before any here can help you.
1. Network topology - exactly how are the 5 switch connected.
2. VLANS used on each switch
3. Is trunking used between switches
4. Make and model of switchews with software version
5. When the problem occurs, how long does the traffic loss last for ?
Posted by Daniel on March 11, 2006, 10:03 am
Everything ends up plugged into a 4506. You have 4 other swithces (other
than the 4506). Two are directly connected to the 4506 and the the last two
are plugged into the 2 that are directly connected to the core switch. So
there is some stacking.
VLANS are setup but disabled. Not sure exactly whey someone did that though.
No trunking.
Switch models are: 4506 and 4 3550 switches.
Problem has no consistency so I can't give you when it occurs. It lasts only
for a few minutes.
Thanks
Posted by Peter on March 11, 2006, 9:54 pm
Hi Daniel,
> No trunking.
> for a few minutes.
Assuming it really is a FLAT LAN (based on no trunking or VLAN's),
then I wonder if you are running into a Spanning-tree issue. Have
extra hosts been sowly added to the network recently? Are you sure
no-one is adding another switch below the "known" switches?
Also your original post states -
and yet above you say -
        "> Switch models are: 4506 and 4 3550 switches"
I assume you meant they are all different MODEL's, not makes?
> consistency.
This could be a spanning-trree or MAC-table type issue.
Cheers.............pk.
Peter from Auckland.
Posted by Daniel on March 11, 2006, 12:55 pm
Thats what I was thinking. But my question is why now? they have been
operating fine for quite a while.
> loop ?
Similar ThreadsPosted
Switch Issues March 10, 2006, 6:01 pm
503 dmz+vpn issues December 14, 2005, 11:19 am
NAT issues March 12, 2007, 9:29 pm
VPN Issues on 837 March 23, 2007, 9:08 am
ASA OS QA issues?? May 30, 2007, 1:18 pm
BGP issues June 27, 2008, 3:59 pm
Switch/Switch problem fibre gigbit ethernet September 6, 2005, 12:33 pm
turn part of the cisco switch into a plain switch February 13, 2007, 1:27 am
trunking between Cisco Catalyst 500 switch and other type of switch March 28, 2006, 1:13 am
VLAN - switch -> trunk -> switch - priority queuing ? August 19, 2006, 2:31 pm
why cisco 2950 switch is called as catalyst switch December 8, 2006, 10:40 am
Cisco VPN issues August 2, 2005, 6:30 pm
VLAN Issues September 22, 2005, 4:18 pm
IOS ipsec issues October 11, 2005, 2:59 am
