Cisco Systems SSL/TCP Connection termination results in RST
Subject Author Date
SSL/TCP Connection termination results in RST Chandler Bing 06-05-08
Posted by Chandler Bing on June 5, 2008, 3:06 pm
My company is working with VeriFone and TSys to isolate issues we've
seen with SSL transactions. We're being told that once one side sends
a FIN, that terminates the entire conversation and indeed the other
side still has data to send and when it performs a PSH, it's ignored
and ultimately the connection is RST. I'm being told by both sides
that this is normal. I don't believe it is.
I have packet captures, but I'm not sure how to post them or share
them out.
Posted by News Reader on June 5, 2008, 8:13 pm
> them out.
My belief is as follows:
A TCP connection is duplex; with an independent stream in each
direction. When one side has no more data to send it can close its half
of the duplex connection.
When a Sender finishes sending its data, it waits for an ACK from the
Receiver, and then may send a FIN segment to close its half of the
connection. The Receiver would ACK the FIN segment, and inform the local
application that no more data will be forthcoming. The Receiver would
not respond immediately with a FIN segment, but would instead wait for a
response from the local application. Prior to receiving a response from
the local application, data should be able to flow on the non-closed
side of the duplex connection, if there is data to send.
When the local application responds with the authorization to shutdown
the 2nd half of the duplex connection, a FIN segment is sent to the
other side. That FIN segment will be ACK'd ending the four-way handshake.
I think a RST is used to close/abort transfers in both directions, and
occurs under abnormal conditions.
That's about all I can offer.
Best Regards,
News Reader
Posted by Thrill5 on June 7, 2008, 12:59 am
A "FIN" means that the connection is being terminated . TCP is full
duplex, but it's one connection. Once a FIN is sent or received, no more
data can be sent or received over that connection. From a protocol level,
the behavior is normal, but the question should be why is the FIN being sent
in the first place? If the connection is being terminated by one side, and
the other needs to send more data, why isn't that side initiating another
TCP connection?
>> them out.
> A TCP connection is duplex; with an independent stream in each direction.
> When one side has no more data to send it can close its half of the duplex
> connection.
> application that no more data will be forthcoming. The Receiver would not
> the local application, data should be able to flow on the non-closed side
> When the local application responds with the authorization to shutdown the
> 2nd half of the duplex connection, a FIN segment is sent to the other
> Best Regards,
> News Reader
Posted by Barry Margolin on June 7, 2008, 10:55 am
Incorrect. A FIN means "I'm not going to send any more", it doesn't
mean "I don't want to receive any more". TCP doesn't have any way to
indicate the latter (other than after the fact, by responding to new
data with an RST).
Barry Margolin, barmar@alum.mit.edu
Arlington, MA
*** PLEASE post questions in newsgroups, not directly to me ***
*** PLEASE don't copy me on replies, I'll read them in the group ***
Posted by Chandler Bing on June 9, 2008, 4:37 pm
> > A "FIN" means that the connection is being terminated . =A0 TCP is full
> > duplex, but it's one connection. =A0Once a FIN is sent or received, no m=
ore
> Incorrect. =A0A FIN means "I'm not going to send any more", it doesn't
> mean "I don't want to receive any more". =A0TCP doesn't have any way to
> data with an RST).
> Barry Margolin, bar...@alum.mit.edu
> Arlington, MA
So any good advice that would tell the vendor to STFU?
Chandler Bing
Similar ThreadsPosted
SSL/TCP Connection termination results in RST June 5, 2008, 3:06 pm
Why do I get these traceroute results? September 28, 2006, 8:35 am
Replacing pix515 with ASA5510 results into MTU problems. May 10, 2006, 9:28 am
PIX VPN termination September 1, 2005, 7:02 pm
1602R w/ both Watchguard and Netgear results in incomplete MAC address July 20, 2006, 9:34 am
VPN termination IP address January 8, 2006, 1:24 pm
VPN termination on routers. January 31, 2006, 4:58 am
Cisco PIX VPN Passthrough and Termination November 21, 2006, 3:11 pm
Obtain Mcse,Ccna And Many More Without Exams(Pay After Check Results)100% Passing Gaurantee July 13, 2006, 10:04 am
termination reason 412 with cisco vpn client October 22, 2008, 2:50 am
ASA 5520 with multiple inside/outside VLANs for VPN termination December 19, 2007, 12:55 pm
feature set required for VPN termination on a cisco 2500 router September 18, 2005, 7:43 am
2600 NM-16A SSH Terminal Server: Termination & Break Sends September 16, 2006, 1:07 am
11503 Content Switch and SSL Termination - Cookie Handling October 11, 2006, 10:34 am
