Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by networkzman on June 24, 2008, 9:48 am
Please log in for more thread options I am trying to configure SPAN on a cisco 6509 cat switch, we are trying to configure ports based span, with three ports as source (which are configured with pvlans) and a destination port on a normal vlan. When I issue a command: set span 3/14,6/7 7/20 both inpkts disable learning enable multicast enable create I get the following error: "Port with a Private Port in the same ASIC can't be made span destination." Please could you someone advise/ suggest as to where I am going worng. Thanks in Advance | |||||||||||||||||||
Posted by Trendkill on June 24, 2008, 10:59 am
Please log in for more thread options Not sure what the exact issue is, but if you are using say 6148's, then ASICs serve every 8 ports (1-8, 9-16, etc). This comes up a lot because on lower end blades (like 6148s), the asics are common bandwidth bottlenecks (as an example, a 6148 can only handle one gig of traffic per asic, so if two ports on the same asic try to push gig throughput, they will instead only get 500mbits each. Anyway, the way around this is probably to set a span destination port that is not in the same asic as any of your source ports. What is your destination port? Your other option is of course to use VACLs. I think you can do multiple VLANs to a single VACL, but been awhile since I tinkered with them. | |||||||||||||||||||
Posted by networkzman on June 25, 2008, 5:58 am
Please log in for more thread options Hello Trend,
Thanks for your suggestion..I was just trying with available free ports to configure as a destination port as you said " ASICs serve every 8 ports (1-8, 9-16, etc). " it seems to be the same in 6509s as well...seleceted one port, while I was checking the pvlan capability for the dest ports.. selected from 1-8 range and it worked. Thanks for your input! >
> > > > > > Hello,
> > trying to configure ports based span, with three ports as source > > (which are configured with pvlans) and a destination port on a normal > > vlan. > > When I issue a command: >
> > set span 3/14,6/7 =A07/20 both inpkts disable learning enable multicast
> > enable create >
> > destination." >
> > Thanks in Advance
> Not sure what the exact issue is, but if you are using say 6148's, > then ASICs serve every 8 ports (1-8, 9-16, etc). =A0This comes up a lot > because on lower end blades (like 6148s), the asics are common > bandwidth bottlenecks (as an example, a 6148 can only handle one gig > of traffic per asic, so if two ports on the same asic try to push gig > throughput, they will instead only get 500mbits each. =A0Anyway, the way > around this is probably to set a span destination port that is not in > the same asic as any of your source ports. =A0What is your destination > port? =A0Your other option is of course to use VACLs. =A0I think you can > do multiple VLANs to a single VACL, but been awhile since I tinkered > with them. | |||||||||||||||||||
| Similar Threads | Posted |
| SPAN + cisco 6500 | June 24, 2008, 9:48 am |
| 2 VLAN's on 1 Port SPAN - CIsco 6500 | December 21, 2007, 1:08 pm |
| enable Span on Cisco Switch 3500 | October 16, 2006, 8:39 am |
| SPAN limitiation | August 24, 2005, 12:30 am |
| Combined SPAN and RSPAN | July 10, 2006, 6:18 am |
| SPAN port on Cat 4006 | April 4, 2008, 9:00 am |
| port span vlan | May 19, 2008, 8:59 pm |
| SPAN and Ingress traffic on 3750 | June 23, 2008, 6:22 pm |
| Catalyst 3560 SPAN setting for Snort | April 26, 2007, 6:07 pm |
| How do you implement SPAN on a 2801 Router with a HWIX-4ESW card installed. | January 2, 2007, 4:02 pm |
| Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable | August 15, 2008, 6:40 am |
| Re: Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable | August 15, 2008, 7:32 am |
| Cat 6500 to Cat 6500 and VLANs | December 1, 2005, 6:01 pm |
| Cisco 6500 + Sup1a or Sup2? | January 2, 2007, 12:33 pm |
| help understanding cisco 6500 products | May 17, 2007, 7:48 pm |
SPAN + cisco 6500
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> vlan.
> enable create
> destination."
> Thanks in Advance
