Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Chavez on May 2, 2008, 1:29 pm
Please log in for more thread options let me know. I have a DSL line from CenturyTel and have been assigned 2 IP addresses. I have 2 routers a Trendnet and a PIX 501. The connection is PPPoE and can authenicate using the Trendnet router for the first IP of x.x.x.29. I need to assign the second IP of x.x.x.30 to the PIX. How do I pass the second IP to the PIX. NAT? Static? | |||||||||||||||||||
Posted by Martin Bilgrav on May 2, 2008, 1:39 pm
Please log in for more thread options to answer your Q: Yes Static NAT - From the 3nd IP to the PIX outside IP. But why do you have the TrendNet router there at all ? Allthough I do not know of this router, i can assume that its about the interfaces, maybe DSL interface or likely. But if ouy can, you should consider using only the PIX Firewall, hence only one device to config and maintain and power etc. HTH Martin | |||||||||||||||||||
Posted by Chavez on May 2, 2008, 1:48 pm
Please log in for more thread options wrote:
> > > I'm not sure if this is the correct group for this post, if not please
> > let me know. I have a DSL line from CenturyTel and have been assigned > > 2 IP addresses. I have 2 routers a Trendnet and a PIX 501. The > > connection is PPPoE and can authenicate using the Trendnet router for > > the first IP of x.x.x.29. I need to assign the second IP of x.x.x.30 > > to the PIX. How do I pass the second IP to the PIX. NAT? Static? >
y
> to answer your Q: Yes Static NAT - From the 3nd IP to the PIX outside IP. > > But why do you have the TrendNet router there at all ? > Allthough I do not know of this router, i can assume that its about the > interfaces, maybe DSL interface or likely. > But if ouy can, you should consider using only the PIX Firewall, hence onl= > one device to config and maintain and power etc.
> > HTH > Martin Martin - thanks for the reply. I work for an oil company that also owns and operates C-Stores. I had the network configured with the Trendnet and was given the PIX by a vendor with instructions to configure it with a public IP. Can I assign the PIX both IP's and maybe V-LAN between the two networks? | |||||||||||||||||||
| Similar Threads | Posted |
| Routing question | March 16, 2006, 3:26 am |
| pix routing question | August 9, 2006, 3:24 pm |
| Re: NAT and Routing Question | August 29, 2006, 2:21 am |
| NAT and Routing Question | August 28, 2006, 11:24 am |
| Routing question | May 23, 2007, 6:23 pm |
| Routing Question | August 13, 2007, 5:49 am |
| Routing question | May 2, 2008, 1:29 pm |
| Question on dynamic routing and PIX VPN | December 6, 2005, 7:22 am |
| Basic Routing question | June 21, 2005, 5:37 pm |
| probably an easy routing question, so please help | May 15, 2007, 3:33 pm |
| static routing question | July 9, 2007, 5:32 pm |
| iBGP Routing Question | August 1, 2007, 6:18 pm |
| Routing Question - Non-contiguous IP Blocks | September 1, 2005, 11:40 am |
| Policy Based Routing Question | November 13, 2005, 7:38 pm |
| Newbie question, routing between two 3620's | March 1, 2006, 4:11 am |
Routing question
Yahoo!
Windows Live
del.icio.us
digg
Netscape
