Cisco Systems Redundant wan link
Subject Author Date
Redundant wan link bensonlei 07-10-08
Posted by on July 10, 2008, 10:10 am
Hi, all,
I have a network topology as the following:
1. Two Cisco 2800 routers,
2. A private line between these two routers,
3. they are running EIGRP
4. Each Router has ASA Firewall and the firewall connecting to the
internet through a broadband
5. A site-to-site VPN is built up between these two firewalls
6. How I configure the Routers and Firewalls in order to form a redunt
WAN network ?
Thanks so much in advance
Posted by PacketU on July 10, 2008, 9:47 pm
> Hi, all,
> WAN network ?
If that is all you have, all you need to do is set the default gateway on
both 2800 to point to the ASA's. If the link goes down, the EIGRP route
will go away and all traffic will go to the ASA on each end. The ASA will
tunnel the traffec based on the crypto policy. It should be that simple.
Cheers.
Posted by on July 11, 2008, 8:54 am
On 7$B7n(B11$BF|(B, $B>e8a(B9$B;~(B47$BJ,(B, "PacketU"
> > Hi, all,
> > WAN network ?
> Cheers.
Hi, All,
I shall test your way later, thanks so much.
Cheers
Similar ThreadsPosted
Redundant wan link July 10, 2008, 10:10 am
redundant link, HSRP? December 6, 2005, 1:37 pm
Redundant link between to L3 switches November 24, 2008, 3:55 pm
Redundant VPN on ASA June 11, 2007, 11:09 pm
Redundant VPN config June 8, 2006, 1:41 am
DMZ with Redundant Pix 525's July 27, 2006, 11:36 am
redundant VPN Tunnel October 2, 2006, 11:44 am
Redundant switch another try March 6, 2008, 10:23 pm
Redundant frame network? February 8, 2005, 2:37 am
Redundant Colocation Setup August 16, 2005, 1:28 am
Redundant links between subnets June 20, 2006, 11:02 am
spantree. No redundant links October 20, 2006, 1:45 pm
[Semi OT] Redundant WAN Connections June 12, 2007, 2:07 pm
Redundant switch second time March 1, 2008, 5:29 pm
Adding redundant Sup720 to 6509 March 8, 2006, 8:20 am
