Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by deano on May 30, 2008, 3:35 pm
Please log in for more thread options port on the 2811 is it posable to have both come through the serial link then break them apart to indivual ports on the cisco. then i could just rout this through the network -- --------------------------------- --- -- - Posted with NewsLeecher v3.9 Final Web @ http://www.newsleecher.com/?usenet ------------------- ----- ---- -- - | ||||||||||||||||
Posted by Trendkill on May 30, 2008, 3:39 pm
Please log in for more thread options Probably. Lets say you had 1.1.1.0/24. Take your external interface, and instead of making it 1.1.1.2/24 (I assume .1 is your provider), set it at 1.1.1.2/25. Then NAT this to your first ethernet port. Then take the second half (1.1.1.128), and put 1.1.1.129/25 on your second ethernet interface. Your only problem with this is that your provider would need to have a route for 1.1.1.128 through 1.1.1.2. You may be able to use some kind of bridge option, but I'm not really sure. I'm sure someone else will speak up who has had a similar situation...... | ||||||||||||||||
| Similar Threads | Posted |
| help IP pass through | May 30, 2008, 2:23 pm |
| Re: help IP pass through | May 30, 2008, 2:58 pm |
| Re: help IP pass through | May 30, 2008, 3:35 pm |
| Re: help IP pass through | May 30, 2008, 4:38 pm |
| VPN-1 Secureremote pass-through on a PIX 506 | December 30, 2005, 12:34 pm |
| VPN Not able to pass traffic. | January 6, 2006, 11:45 am |
| Cisco PIX pass through VPN | November 16, 2005, 6:54 pm |
| Cisco PIX pass through VPN | November 16, 2005, 6:55 pm |
| PIX 704 Connat pass traffix | December 8, 2005, 2:00 pm |
| 837 vs 857 PPTP Pass through Problems | May 8, 2006, 9:39 pm |
| cisco 76x and PPTP pass through? | June 18, 2006, 3:49 pm |
| pptp pass thru cisco 857 | July 26, 2006, 8:27 am |
| Pass-Guaranteed.com Now Hiring!!! | January 10, 2007, 6:27 pm |
| Pass IT exams by TEST104 | November 6, 2007, 3:52 am |
| Need to pass vlan info over ATM | April 23, 2008, 9:35 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> Web @http://www.newsleecher.com/?usenet
