Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Aaron Leonard on November 27, 2007, 1:19 pm
I didn't catch which IOS version you're running ... it used to be that AIR-LAP model APs that were running aIOS reported a bogus OID value, which kept them from being manageable by WLSE - this was fixed via CSCsc68458 in 12.3(7)JA4 12.3(8)JA. I'm a little fuzzy on the details of the fix ... if you're running IOS with the CSCsc68458 fix yet are still seeing this problem in Cisco Network Assistant, then your next step would be to teach CNA about this model. Maybe it has a table that you can edit. Aaron ---- ~ Hi all, ~ ~ I'm hoping someone can tell me why this is happening... ~ ~ I recently configured a 1131 AP from Lightweight to Autonomous Mode ~ (flashed another IOS). ~ AP works fine in every way, except one... ~ ~ When trying to access it via/make it a member of a community, the ~ following error message appears: ~ ~ "Unsupported device type: AIR-LAP1131AG-K-E9 ~ Cannot add device <ip address> to community" ~ ~ Community has other similar devices that also work fine but do not ~ give this error -- the only two differences being that the other AP's ~ were shipped as Autonomous Mode AP's, and the one giving the problem ~ was converted from LW to AM. Also, the other AP's are advertising as ~ "AIR-AP1131AG" instead of "AIR-LAP1131AG-K-E9". ~ ~ Could either (or both) cause the problem? ~ ~ If device is still advertising itself as a LM model (apparently not ~ manageable with Cisco Network Assistant), is there a variable, string ~ or register that can be changed, or I should just pick another IOS ~ version? ~ ~ ~ Any help would ge greatly appreciated! ~ Thanks! ~ ~ M.T. ~ ~ PS: Email is a decoy -- please reply within thread. | |||||||
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language! Click Here to learn more |
Re: Q: Cisco AP 1131 -- "Unsupported device type" error in Cisco Network Assistant
Yahoo!
Windows Live
del.icio.us
digg
Netscape
