Posted by Doug McIntyre on June 23, 2009, 11:41 am
>I have the below config on a 3620 router. No troubles with anything
>else whatsoever other than getting VPN access. I have "ip nat inside
>source static tcp 192.168.0.4 1723 interface Dialer0 1723" set to
>forward port 1723 to my VPN system.
Port 1723 must be PPTP, which uses more than just UDP port 1723. It
also uses the GRE IP protocol. Most simplistic routers just do what it
thinks you want. Cisco's tend to do exactly what you tell it.
You'll have to permit GRE through as well. Here's a Cisco tech note.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094a5a.shtml
| Similar Threads | Posted |
| Re: Port 1723 being blocked | June 23, 2009, 11:41 am |
| port-being blocked | June 28, 2005, 5:40 am |
| Port blocked - Cisco router or PIX | November 30, 2006, 3:19 pm |
| Open for Windows 2000 server VPN (1723) - HOW-TO | May 26, 2007, 5:57 am |
| Socks5 getting blocked? | December 18, 2007, 2:34 pm |
| spanning tree blocked ports in MIB? | July 29, 2006, 4:12 pm |
| now open all blocked site with our proxy | January 3, 2010, 3:56 am |
| open all blocked sites in your country now | January 6, 2010, 2:51 pm |
| cisco access lists blocked packets | September 23, 2005, 7:05 am |
| ISDN Problem - Outgoing Call id 0x8013 blocked | September 5, 2006, 6:10 am |
| Problems with 7206 vxr trying to VLAN a Gig port to an HP 4000M Gig port over fiber | September 9, 2007, 2:38 pm |
| Cisco 1-Port 10 Gigabit Ethernet LAN/WAN-PHY Shared Port Adapter | March 8, 2010, 9:47 am |
| EMUTEL 15 port BRI / 2 port PRI ISDN simulator help wanted | February 7, 2005, 1:19 pm |
| pix denying port 80 also stopped an application on port 8080 | January 22, 2008, 7:05 pm |
| Port mirroring in HP 2626-pwr 24 port switch | October 25, 2005, 5:01 am |
