Cisco Systems Re: PIX 501 blocking inside to out arp requests
Subject Author Date
Re: PIX 501 blocking inside to out arp requests Doug McIntyre 05-20-08
Posted by Doug McIntyre on May 20, 2008, 10:12 am
>I've got a Cisco PIX 501 that I like to use as my boarder firewall/
>router for my home. However, I have found one situation where I have
>to swap the 501 for a dumb Linksys router/NAT device.
>I work from home as a software consultant, and one of the clients I
>work for has a VPN concentrator that I can not connect to with my PIX
>inline.
>I think I have narrowed it down to the VPN Adapter that is created
>when I connect to their concentrator.
Probably not..
>There is no 'Default Gateway'. With the PIX in line I can not connect
>to their server 192.168.15.2, etc.. With the Linksys in line every
>thing seems to work fine.
Do you have the PIX configured to let IPsec packets through?
sysopt connection permit-ipsec
I'm assuming you are already doing NAT-T on your VPN setup since you
say the Linksys one works.
>I'm guessing (as I'm no network guru) that the Linksys router is
>allowing ARP requests to traverse the device, and the PIX is blocking
>them since there is now pre-defined route, or maybe this guess is way
>off, I don't really know.
Yes, this guess is way off..
Posted by Tyler on May 20, 2008, 10:42 am
I did not have this statement in my config.
However, other sites that I VPN to worked fine, all "seem" to be
configured using IPSec over UDP (NAT / PAT) in the Cisco VPN Client
I'm using to connect to the client through my PIX / Linksys router.
I have added the statement to my PIX, but I haven't had a chance to
test it yet as the PIX is currently not hooked up. I'll give it a
test later today when I disconnect from the client I'm working with.
Thanks
Posted by Tyler on May 21, 2008, 11:47 pm
Any other ideas?
Posted by Marko Uusitalo on May 22, 2008, 4:00 am
Tyler kirjoitti:
> Any other ideas?
I the dns server 192.168.1.10 in your network or across the VPN? This
could be the problem. Can you connect using IP addresses only
Regards
Marko
Similar ThreadsPosted
Re: PIX 501 blocking inside to out arp requests May 20, 2008, 10:12 am
Unable to make DNS requests from inside the DMZ March 15, 2007, 3:14 pm
pix 501 - Problem Routing Requests from inside to outside networks November 27, 2007, 5:59 am
DHCP requests August 27, 2007, 12:54 pm
ntp requests routed wrong December 21, 2005, 12:36 pm
PIX 501 relay client DNS requests out to an internet DNS server? November 17, 2006, 5:43 pm
Configuring an inside nat group on inside interface April 10, 2006, 4:38 pm
MSN, ... blocking ? September 13, 2005, 9:19 am
Blocking IM November 13, 2006, 2:08 pm
ACL blocking dns May 21, 2008, 4:49 pm
Blocking myspace.com January 3, 2006, 11:30 pm
blocking Bittorrent April 17, 2006, 10:53 pm
Port 25 blocking ???? September 12, 2006, 1:25 pm
Blocking Skype? December 15, 2006, 10:39 am
Cisco 837 - how to set up Inside to Inside NAT for DNS resolution? May 23, 2006, 2:00 pm
