Posted by Trendkill on August 15, 2008, 7:32 am
> > > Thanks for your answer,
> > > do you know the process for put it "On" on the cisco 6500 ?
> > > Thanks
> > > headsetadapter.com a =E9crit :
> > > > Hi Mag,
> > > > Catalyst 3524XL definitely do not have MDIX capablitiy for the ports (you
> > > > can confirm it with "show interface capability" command). Catalyst 6500 has
> > > > it on *some* blades, but you may need to enable it (it's off by default).
> > > > Good luck,
> > > > Mike
> > > > CCNP, CCDP, CCSP, CCVP, MCSE W2K, MCSE+I, Security+, etc.
> > > > CCIE Voice (in progress), CCIE R&S (next)
> > > > Headset Adapters for Cisco IP Phones
> > > >www.ciscoheadsetadapter.com
> > > >www.headsetadapter.com
> > > >> Hi
> > > >> If i connect the C3524XL to a Cisco 6500 with a classic
> > > >> RJ45 cable, i don't have the link. If i use a crossover cable, i have the
> > > >> link.
> > > >> I think's that =A0C3524/6500 don't have auto mdi.
> > > >> Anyone know if i can said by the cisco IOS that the port are connected
> > > >> to another switch without a crossover cable ? "MDI by software"
> > > >> thanks
> > > >> mag
> > On the cat side I think it is : set port auto-mdix enable. =A0Not sure
> > on the native side.
> Sorry, forgot the mod/port!
> set port auto-mdix mod/port {enable | disable}
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command=
/reference/set_m_pi.html#wp1045648
Posted by Mag on August 15, 2008, 7:36 am
Thanks for your answer, but i am not in CatOS, on my cisco 6500, it's a
IOS
>>>> Thanks
>>>> headsetadapter.com a écrit :
>>>>> Hi Mag,
>>>>> Good luck,
>>>>> Mike
>>>>>> Hi
>>>>>> link.
>>>>>> I think's that C3524/6500 don't have auto mdi.
>>>>>> thanks
>>>>>> mag
>>> On the cat side I think it is : set port auto-mdix enable. Not sure
>>> on the native side.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/set_m_pi.html#wp1045648
Posted by Trendkill on August 15, 2008, 7:46 am
It looks like the command is:
int mod/port
mdix auto
or
no mdix auto
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/=
command/reference/I1.html#wp1271678
| Similar Threads | Posted |
| Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable | August 15, 2008, 6:40 am |
| Re: Connect a cisco catalyst 3524XL to a Cisco 6500 ? Auto-MDI or crossover cable | August 15, 2008, 7:32 am |
| Without Crossover Cable | September 25, 2006, 8:33 pm |
| Re: DB60 crossover cable | August 29, 2006, 10:30 pm |
| DB60 crossover cable | August 28, 2006, 12:27 pm |
| Cisco Catalyst 6500 and VPLS ? | December 29, 2008, 4:06 am |
| Cisco IOS naming for Catalyst 6500 Series | April 27, 2010, 5:16 am |
| Connecting 3 switches to a fourth switch, each with its own crossover cable shuts down ports | March 29, 2007, 2:04 pm |
| Point-to-point T1 with 2620XM and crossover cable | April 25, 2006, 4:59 pm |
| Cross over cable or straight to connect to 2811 from T1? | November 22, 2006, 4:59 pm |
| Cisco 1811 K9- VPN clients can connect, but can't connect or ping to computers | January 30, 2009, 4:30 pm |
| Catalyst 6500 help | October 9, 2007, 2:42 pm |
| catalyst 6500 power | February 20, 2006, 5:23 am |
| Catalyst 6500 [FWSM] [CSM] | May 4, 2006, 3:51 am |
| Help with NAT configuration on a Catalyst 6500 with no FWSM | December 6, 2006, 5:49 pm |
> > > Thanks
> > > > Hi Mag,
> > > > Good luck,
> > > > Mike
> > > >> Hi
> > > >> link.
> > > >> thanks
> > > >> mag
> > on the native side.
