Cisco Systems Re: Cisco 2600 ADSL with failover to Ethernet with NAT
Subject Author Date
Re: Cisco 2600 ADSL with failover to Ethernet with NAT Jack 05-28-08
Posted by Jack on May 28, 2008, 4:26 pm
After a bit of testing I seem to have come to a stable solutions using
my config above.
When the Dialer1 interface is shutdown the config switches to NAT over
Eth0/0.
Upon re-activation of Dialer1, new NAT will start to go via Dialer1,
but any existing connections will continue via Eth0/0 as long as
Eth0/0 is up.
So it seems to be working...
Jack
Posted by on May 29, 2008, 3:35 am
> my config above.
> Eth0/0.
> Eth0/0 is up.
> Jack
As discussed above - does it fail over when you
unplug the DSL instead - or even maybe
shut the ATM interface.
My memory is that dialers are always UP.
This is not 100% though.
Similar ThreadsPosted
Re: Cisco 2600 ADSL with failover to Ethernet with NAT May 28, 2008, 7:08 am
Re: Cisco 2600 ADSL with failover to Ethernet with NAT May 28, 2008, 4:26 pm
Cisco 2600 ISDN Failover Configuration April 25, 2006, 3:59 pm
Cisco 2600 + DSL + Cable -> Failover and port forwarding July 2, 2008, 12:47 am
power over ethernet, cisco 2600 router November 23, 2008, 3:02 pm
Failover from SDSL to ADSL on a single Cisco 2801 February 9, 2006, 8:47 pm
Failover of Ethernet links with Cisco Routers January 16, 2008, 10:20 am
ADSL disconnects randomly on 2600. July 11, 2005, 11:32 pm
Can I connect 3700 to 2600 via ethernet? March 21, 2007, 1:23 pm
cisco ASA/PIX failover and VPN, failover IP access problem August 27, 2008, 11:34 am
Config for cisco 1841 with one adsl for internet and one adsl for vpn October 29, 2006, 3:31 am
Simple Ethernet to Ethernet setup (cisco 1605R) But I can't get it to work. July 7, 2005, 12:59 pm
PWR-2600-AC 2600 power supply to switch over a DC router? August 7, 2008, 9:16 pm
2600 cisco March 31, 2008, 3:14 pm
Cisco 2600 Router September 30, 2005, 12:09 am
