Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Dan Lanciani on August 19, 2007, 4:25 pm
Please log in for more thread options | | | 3640 supports a maximum flash memory size of 32 MB = 32,768,000 | bytes. | | The ENTERPRISE/FW/IDS PLUS IPSEC 3DES ( c3640-jk9o3s-mz-124-16.bin) | image size of 34,755,788 bytes exceeds that amount. | | It would seem that Cisco has posted an image on CCO that cannot be | loaded onto a 3640. Well, you can load it in the sense that you can rcp (or ftp) boot it; I tried the other day. I actually think it's kind of nice that they not stop releasing images just because the images got too big for flash, but then I'm not trying to use a 3640 for production. :) Dan Lanciani ddl@danlan.*com | ||||||||||||||||
Posted by Jay Franklin on August 25, 2007, 4:46 pm
Please log in for more thread options have a pcmcia card, but its only 20MB. afaik, the max pcmcia flash that the 3600 series supports is 20mb. is this correct? thanks. Jay ps- it seems the latest 3620 enterprise/fw/ids ipsec 3des also doesnt fit into the max flash. just for the record. | ||||||||||||||||
| Similar Threads | Posted |
| Re: 3640 latest 124-16 wont fit in flash | August 18, 2007, 11:12 pm |
| Re: 3640 latest 124-16 wont fit in flash | August 19, 2007, 4:25 pm |
| Upgrading flash -> 32 mb. Cisco 3640 | July 22, 2005, 6:56 pm |
| Amount of flash simms in 3640 | September 12, 2006, 7:06 am |
| 3750G wont post | January 8, 2007, 4:26 pm |
| New FR Circuit Wont Stat Up | October 15, 2007, 2:16 pm |
| router wont prompt enable | August 15, 2005, 7:21 am |
| One machine wont connect to 3500XL | February 14, 2007, 7:57 pm |
| Cisco 857 Ethernet0 wont stay up unless constant ping is done. | June 23, 2006, 11:55 am |
| Cisco Router wont allow telnet over port 9999 | July 7, 2006, 2:47 pm |
| Latest OS for PIX 501? | November 7, 2005, 3:13 pm |
| 2948G-L# latest IOS?? | November 7, 2005, 10:11 pm |
| Help! How can I get the latest IOS for my new 837 router? | April 27, 2006, 10:27 am |
| Latest IOS versions | September 26, 2007, 9:37 pm |
| latest IOS for 2916M-XL switch | January 9, 2006, 9:47 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
