Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Dan Lanciani on August 18, 2007, 11:12 pm
Please log in for more thread options | im trying to load the latest 3640 ios (c3640-jk9o3s-mz-124-16.bin), | however with max 32mb flash i cant load it. it says not enough space | on device. im currently running jk9o3s-mz-124-5a. on my linux box ls - | l shows 34755788. You can boot it by rcp (or ftp). I don't think tftp is practical unless big block support works. Note that whatever IOS image rommon uses as the helper to execute the rcp/ftp boot needs to be small enough for both itself and 12.4(13) to fit in memory. This obviously precludes using a recent jk9o3s image as the helper. By default rommon uses the first flash image as the helper. You can change this by setting the BOOTLDR monitor variable. I stuck an old 12.0 IP-only image in flash to use as the helper and pointed BOOTLDR at it. I'm not sure there is room to have the last jk9o3s image that fit plus an image that can load 12.4(13); anybody know the smallest image that will work for the latter? Maybe with a PCMCIA flash card... Note that configuring "boot system" statements from IOS does update the rommon BOOT variable as expected, but "boot bootstrap" statements do not update the BOOTLDR variable and there seems to be no "boot bootldr" even though it is mentioned in the documentation. Also, there is no "show bootvar" or "show bootenv" or such to see what the monitor thinks about the world from the IOS CLI. Dan Lanciani ddl@danlan.*com | ||||||||||
| Similar Threads | Posted |
| Re: 3640 latest 124-16 wont fit in flash | August 18, 2007, 11:12 pm |
| Re: 3640 latest 124-16 wont fit in flash | August 19, 2007, 4:25 pm |
| Upgrading flash -> 32 mb. Cisco 3640 | July 22, 2005, 6:56 pm |
| Amount of flash simms in 3640 | September 12, 2006, 7:06 am |
| 3750G wont post | January 8, 2007, 4:26 pm |
| New FR Circuit Wont Stat Up | October 15, 2007, 2:16 pm |
| router wont prompt enable | August 15, 2005, 7:21 am |
| One machine wont connect to 3500XL | February 14, 2007, 7:57 pm |
| Cisco 857 Ethernet0 wont stay up unless constant ping is done. | June 23, 2006, 11:55 am |
| Cisco Router wont allow telnet over port 9999 | July 7, 2006, 2:47 pm |
| Latest OS for PIX 501? | November 7, 2005, 3:13 pm |
| 2948G-L# latest IOS?? | November 7, 2005, 10:11 pm |
| Help! How can I get the latest IOS for my new 837 router? | April 27, 2006, 10:27 am |
| Latest IOS versions | September 26, 2007, 9:37 pm |
| latest IOS for 2916M-XL switch | January 9, 2006, 9:47 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
